Local Time 21:55 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite - response of an esc control sequence?
homa
Posted: 10:54pm 13 Nov 2021
how can i evaluate the response of an esc control sequence? this is output again directly at the terminal ...
Cursor Position Report
Invoked by ESC [ 6 n
Response is ESC [ Pl ; Pc R *
* Pl = line number; Pc = column number
> ? chr$(27)+"[6n";
> [24;1R
It is logical that this does not work:
> x=print chr$(27)+"[6n";
Error : Expression syntax
or that:
> line input chr$(27)+"[6n", test$
[9;1R
> print test$
But how then?
Posted: 11:05pm 13 Nov 2021
test$ = chr$(27)+"[6n"
print test$
line input test$,answer$
print answer$
I think is what you are trying to do.
I am not sure if your terminal appends the CRLF and if not, you cannot use line input
Posted: 11:57pm 13 Nov 2021
this probably demonstrates what you're after:
Const ESC=Chr$(27)
Print ESC "[2J";
 Print ESC "[" Str$(1+(Rnd*20),0,0) ";" Str$(1+(Rnd*75),0,0) "f";
 Print "#" Chr$(8);
 A$=""
 I%=Timer+100
 Print ESC "[6n";
   A$=A$+Inkey$
 Loop Until (Right$(A$,1)="R") Or Timer>I%
 A$=Mid$(A$,3,Len(A$)-3)
 Print ESC "[23;1f" A$ Space$(8);
 Print ESC "[" A$ "f";
 Pause 2000
rob   :-)
Edited 2021-11-14 12:14 by robert.rozee
Posted: 08:12am 14 Nov 2021
you may find this usefule
http://www.fruitoftheshed.com/MMBasic.Simple-screen-Control-for-ANSI-based-Consoles-VT100-etc.ashx
and this which provides a more controllable "input" using the above
http://www.fruitoftheshed.com/MMBasic.String-editing-on-screen-for-VT-compatible-Terminals.ashx
<deleted duplicate>
Edited 2021-11-14 18:13 by CaptainBoing
homa
Posted: 07:09pm 14 Nov 2021
thanks to all, I will try out the suggestions and examples and report back ...
homa
Posted: 10:30pm 15 Nov 2021
There seems to be a difference between testing line input at the prompt and in the programme! Unfortunately, only the CRLF is really missing :-( in the programme version.
I am not sure if your terminal appends the CRLF and if not, you cannot use line input.
It is a pity that it is not provided from the basic system. With the Inkey$ query with the Do Loop, keystrokes (especially the ESC key) can mess up a clean query :-( Here the system would have to ask the query and prevent any other input and react immediately to the ESC response, only then should the normal Inkey$ be used again.
So far I am not satisfied with any solution and will probably calculate the cursor position after a clear screen for all outputs and then always have the cursor position available. Or am I missing something in the examples, thanks for that.
But beautiful is different, isn't it?
Posted: 11:36pm 15 Nov 2021
The device doesn't know how fast the characters are arriving and how long a line will be so you cannot rely on line input.
Serial comms is always going to require work on the programmers behalf.
How you do it depends on your overall program flow.
I am sorry that I can't provide you with a 'simple' solution.
