Local Time 21:55 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite ' PORT ' ......
hitsware2
Posted: 12:22am 11 Nov 2021
' PORT test
SetPin gp16,din,pullup
SetPin gp17,din,pullup
SetPin gp18,din,pullup
SetPin gp19,din,pullup
Print Pin(gp16)
Print Pin(gp17)
Print Pin(gp18)
Print Pin(gp19)
Print Port(gp16,gp17,gp18,gp19)
' Gives me:
'1
'1
'1
'1
'0
'Also if I try just 3 pins,
'I get 'syntax' error on PRINT PORT ?
my site
Posted: 12:59am 11 Nov 2021
Try this:
Print Pin(gp16)
Print Pin(gp17)
Print Pin(gp18)
Print Pin(gp19)
Print Port(gp16,4)
Print "0x"+Hex$(Port(gp16,4))
Print "0b"+Bin$(Port(gp16,4))
See PIN in the Functions list in the manual, not the Commands list, to see why.
hitsware2
Posted: 01:15am 11 Nov 2021
Thank You ! ...
I ' ve decided to use :
p=pin(gp16)+2*pin(gp17)+4*pin(gp18)+8*pin(gp19)
So I don't have to use consecutive pin numbers .
my site
Posted: 01:28am 11 Nov 2021
You don't have to use consecutive pin numbers. This also works:
SetPin gp20,din
SetPin gp22,din,pullup
Print Pin(gp16)
Print Pin(gp17)
Print Pin(gp18)
Print Pin(gp19)
Print "0b"+Bin$(Port(gp16,1,gp18,1,gp20,1,gp22,1))
hitsware2
Posted: 01:54am 11 Nov 2021
Set a number of I/O pins simultaneously (i.e. with one command).
'start' is an I/O pin number and the lowest bit in 'value' (bit 0) will be used to
set that pin. Bit 1 will be used to set the pin 'start' plus 1, bit 2 will set pin
'start'+2 and so on for 'nbr' number of bits.
I/O pins used must be numbered consecutively
and any I/O pin that is invalid or not configured as an output
will cause an error. The start/nbr pair can be repeated if an additional group
of output pins needed to be added.
For example; PORT(15, 4, 23, 4) = &B10000011
Will set eight I/O pins. Pins 15 and 16 will be set high while 17, 18, 23, 24
and 25 will be set to a low and finally 26 will be set high.
This command can be used to conveniently communicate with parallel
devices like LCD displays. Any number of I/O pins (and therefore bits) c
my site
Posted: 04:37am 11 Nov 2021
Yes, if you specify MORE then ONE pin in the PORT command, the pins have to be consecutive.  However, as illustrated by lizby above, you can have completely random pin numbers making up the port, but you have to specify them all separately and as only one pin each.
Posted: 12:39pm 11 Nov 2021
  hitsware2 said  Set a number of I/O pins simultaneously (i.e. with one command).
With "set", you're using PORT as a command. If you do PRINT PORT ..., then PORT is a function.
