Local Time 19:58 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V5.07.01 betas
     Page 1 of 5
Posted: 10:23am 30 Oct 2021
http://geoffg.net/Downloads/picomite/PicoMite_Beta.zip
V5.07.01b1
Fixed Bug in epoch function which changed date$.
Changed maximum WS2812 LEDs to 256
MM.INFO(pinno GPnn) implemented to give physical pin number for a given GP number
robscott
Posted: 02:03pm 30 Oct 2021
All tested , works as advertised
Thanks Again
Rob
Posted: 02:43pm 31 Oct 2021
Implements a logarithmic scale for the volume control so that PLAY VOLUME 50,50 should sound half as loud as 100,100
Also applies to PLAY SOUND n, ch, type, freq [,vol]
Must also do this for the CMM2
wolfme
Posted: 06:20pm 31 Oct 2021
Thanks very much!
I noticed the epoch bug earlier and now already fixed...
Wolfgang
Posted: 06:44pm 31 Oct 2021
Hmmm... so now I'll need an antilog table if I feel the urge to use a 'mite as a signal generator with calibrated output voltage...   ;)
Edited 2021-11-01 04:45 by Mixtel90
lew247
Posted: 08:22pm 31 Oct 2021
  Mixtel90 said  Hmmm... so now I'll need an antilog table if I feel the urge to use a 'mite as a signal generator with calibrated output voltage...   ;)
Why?
it's only the sound output that's been changed to log, as per radio colume controls
normal functions should still be linear
Posted: 07:31am 01 Nov 2021
Because, with a log function, you couldn't easily set fixed outputs of, say, 100mV, 300mV and 500mV. 1V doesn't sound twice as loud as 500mV. This is only of interest for audio test signal generation, where you are more interested in the signal level than its apparent volume. Your ears have a logarithmic level response (hence log volume controls), devices under test rarely are (even when you want them to be!). PLAY SOUND is of interest because it produces useful waveforms.
TBH, it's probably of very little interest really. Far more people will be interested in "double the number to make it twice as loud" than are interested in audio signal generation. :)  In any case, the output from the 'mites is unlikely to be clean enough (at low levels) because of the computer "hash" noise on the signal. That means filters, those mean non-linearity.
Edited 2021-11-01 17:47 by Mixtel90
Posted: 07:48am 01 Nov 2021
  Quote  Because, with a log function, you couldn't easily set fixed outputs of, say, 100mV, 300mV and 500mV.
PWM ?
Posted: 07:53am 01 Nov 2021
And add more noise to the signal?  ;)
It's not really an issue. It was just an alternative view. If I wanted a few fixed level outputs that's easy - just put the scope on and set up a table of values for the levels I want.
Posted: 08:24am 02 Nov 2021
Fixes bug in SETPIN pinno,IR
Fixes bug in parameters following subcommands/sub-functions that are enclosed in brackets e.g. POKE WORD (anything),anything or ? PEEK(WORD (anytthing))
Allows variables or string literals in the SOUND command for both the channel and sound type. The original syntax is still also allowed
Posted: 08:38am 02 Nov 2021
Yay!
Posted: 03:41pm 02 Nov 2021
V5.07.01b4
YOU MUST EXECUTE OPTION RESET BEFORE LOADING THIS VERSION
Implements the option of using a standard uart as the console
OPTION SERIAL CONSOLE uartapin, uartbpin
uartapin and uartbpin can be any valid pair of rx and tx pins for either com1 (uart0) or com2( uart1). The order you specify them is not important
Use
OPTION SERIAL CONSOLE DISABLE
to revert to normal the USB console
Edited 2021-11-03 01:42 by matherp
Posted: 04:34pm 02 Nov 2021
  matherp said  Implements the option of using a standard uart as the console
Well ok.
Though I'm not exactly sure where I would go next with this.
(Better put a note on this to remind me that it's on UART console; otherwise I'll be befuddled if I try to access it through USB.)
Posted: 04:40pm 02 Nov 2021
Well, the next stage is probably to connect it to Geoff's VT100 terminal. :)
bigfix
Posted: 04:57pm 02 Nov 2021
Or use ESPterm on a ESP8266 and get a WEB interface to any browser
ESPterm on Backshed
I cannot test it as I am refurbing some rooms and my parts are boxed up somewhere...
Edited 2021-11-03 03:00 by bigfix
karlelch
Posted: 05:42pm 02 Nov 2021
Very cool!
Now I can program via a simple bluetooth link using two HC-05 modules :-)
Posted: 11:38am 03 Nov 2021
V5.07.01b5
YOU MUST EXECUTE OPTION RESET BEFORE LOADING THIS VERSION IF PREVIOUSLY USING LESS THAN b4
This is a re-compile using the latest sdk. Please report any issues
Posted: 11:56am 03 Nov 2021
Out of curiosity, how much firmware flash space remains available on the PicoMite, and how much has been used?
Posted: 12:03pm 03 Nov 2021
478K out of 1024K
Calli
Posted: 02:55pm 03 Nov 2021
  karlelch said  Very cool!
That sensor array is impressive!
Greets from the evil twin:
I have few time at my hands these days, but... SOME DAY...
atm there is a Tiny RP2040 in there, time to test PicoMite on it.
Carsten
     Page 1 of 5
