Forum Index : Microcontroller and PC projects : PicoMite i2c scanner
| Calli Regular Member Joined: 20/10/2021 Location: GermanyPosts: 74 |
I did a i2c scanner like i2cdetect in linux. Maybe helpfull for stuff :) (I try to get a VL53L0X to talk to me) ' i2cdetect like program ' Set Pins! SetPin gp8, gp9, I2C ' Open first I2C I2C open 100, 200 ' Prep table Print " 0 1 2 3 4 5 6 7 8 9 A B C D E F" ' loop col/row For y=0 To 7 Print Hex$(y,2);": "; For x=0 To 15 addr = y*16+x ' calc address I2C write addr, 0, 1, &H00 ' write zerp to that adress If MM.I2C=0 Then ' check for errors Print Hex$(addr,2);" "; ' found one! Else Print "-- "; ' nothing here.. EndIf Next x Next y I2C close ' clean up Output: 0 1 2 3 4 5 6 7 8 9 A B C D E F 00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 01: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 02: -- -- -- -- -- -- -- -- -- 29 -- -- -- -- -- -- 03: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 04: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 05: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 06: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 07: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- Best, Carsten |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9259 |
That looks useful, thanks. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1783 |
Hi Carsten, welcome to the TBS! Your scanner seems very usefull and good looking! I hope there will be a lot more code examples! FYI: A similar scanner was one of my first projects for MMBasic too. Best regards Michael Edited 2021-10-29 04:44 by twofingers |
Sharing is caring :) Thanks! Carsten |
| steview_de Newbie Joined: 02/11/2022 Location: GermanyPosts: 12 |
Hey Calli, thanks for the useful code. Due to "OPTION xxx" i dont need SetPin and I2C open for my purpose. "Stevie" |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3418 |
Here is a PicoMite System I2C and I2C2 Address Scanner. Print "PicoMite System I2C and I2C2 Address Scanner" ' SDA = 4 : SCL = 5 ' I2C2 pins. Change pins to your usage, 0 if no I2C2 ' (Do NOT use GP numbers, standard Pico RP2040 module pin numbers only) again = 1 Print "For System I2C" Scan If SDA Then SetPin SDA, SCL, i2c2 I2C2 open 100,1000 Print "For I2C2 - SDA = Pin("SDA"), SCL = Pin("SCL")" again = 0 Scan I2C2 close Else Print "I2C2 not configured" EndIf ' Sub Scan Print " 0 1 2 3 4 5 6 7 8 9 A B C D E F" ' Prep table ' loop col/row For y=0 To 7 Print Hex$(y,2);": "; For x=0 To 15 addr = y*16+x ' calc address If again Then On Error Skip 3 I2C write addr, 0, 1, &H00 ' write 0 to that adress Else I2C2 write addr, 0, 1, &H00 ' write 0 to that adress EndIf If MM.Errno = 0 Then If MM.I2C=0 Then ' check for errors Print Hex$(addr,2);" "; ' found one! device=addr Else Print "-- "; ' nothing here.. EndIf Else Print " I2C not configured" EndIf Next x ' -------------- Add your favorite devices here ------------------ If device = &H68 Then : Print "RTC DS3232, DS1307 etc"; : device=0 : EndIf If (device > &H49) And (device < &H58) Then : Print "24Cxx EEPROM"; : device=0 : EndIf If device = &H3C Then : Print "LCD SSD1306"; : device=0 : EndIf Next y End Sub |
