Forum Index : Microcontroller and PC projects : Lora Modul - Mmbasic code ?
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
Hi , anyone able to run a lora modul (sx1276 or rfm95) with mmbasic ? Thx Plasma |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 421 |
Hi, I did some LoRa testing a few years ago with the standard 28pin Micromite & ILI9341 LCD. I found some programs on internet. Modified slightly to fit my purpose. I was testing with one unit dedicated for TX and the other for RX. The TX-unit sends a test message with stepvise increasing output power and the RX-unit displays the communication info including the used TX-power. Based on the test results you can determine what power level you need for your communication purpose. LoRa.zip Unfortunately I can not anymore recall how far I was able to reach with the LoRa-modules (Ra-02, Ai-Thinker from Ali Express). |
Thx ill check the source Plasma |
