Local Time 00:27 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Snadpic info
Glen0
Posted: 12:09am 22 Oct 2021
Trying to use up the 2 Snadpics I aquired a long time ago.
Could someone please point me to where I can find info on using these with MMBasic.
I recall seeing it discussed quite a lot in the early days on a few threads but I have not been able to find them.
Much appreciated ( in advance)
led-bloon
Posted: 01:41am 22 Oct 2021
Try in your favourite search engine:
  Quote  snadpic site:thebackshed.com
Heaps of responses using DuckDuckGo
led
Miss you George
Glen0
Posted: 09:49am 22 Oct 2021
Cheers, that's it. found it in the mm extreme manual. forgot about that.
Phil23
Posted: 09:05am 26 Oct 2021
  Glen0 said  Cheers, that's it. found it in the mm extreme manual. forgot about that.
I thing the MM+ manual would be more applicable.
Basically it's the same chip as in the E100.
See https://geoffg.net/micromite.html
Posted: 10:03am 26 Oct 2021
  Quote  I thing the MM+ manual would be more applicable.
The snadpic was available with various different processors. I used one to develop the MMX. If the processor is a MZ then you need the MMX firmware
