Local Time 01:16 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Bug with MEMORY SET of user failure ?
Posted: 09:08pm 07 Oct 2021
What do we think of this one ?
> 480MHz Colour Maximite 2 G2
MMBasic Version 5.07.01
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> list "memory_set_short_test.bas"
Option Base 0
Dim buf%(31) ' 256 bytes
Dim addr% = Peek(VarAddr buf%())
Memory Set Short addr% + 2, &hABCD, 4
Print "&h" Hex$(Peek(Short addr% + 0), 4) " should be &h0000"
Print "&h" Hex$(Peek(Short addr% + 2), 4) " should be &hABCD"
Print "&h" Hex$(Peek(Short addr% + 4), 4) " should be &hABCD"
Print "&h" Hex$(Peek(Short addr% + 6), 4) " should be &hABCD"
Print "&h" Hex$(Peek(Short addr% + 8), 4) " should be &hABCD"
Print "&h" Hex$(Peek(Short addr% + 10), 4) " should be &h0000"
> run "memory_set_short_test.bas"
&h0000 should be &h0000
&hABCD should be &hABCD
&hCDCD should be &hABCD
&h00CD should be &hABCD
&h0000 should be &hABCD
Posted: 09:49pm 07 Oct 2021
Will look tomorrow
Posted: 09:07am 08 Oct 2021
Have fixed the code ready for next release. Obviously the code isn't relevant to your port as it uses the ARM assembler routines to do things that memset can't do.
Thanks for the report
Posted: 09:14am 08 Oct 2021
  matherp said  Have fixed the code ready for next release. Obviously the code isn't relevant to your port as it uses the ARM assembler routines to do things that memset can't do.
Thanks, it already works in MMB4L (assuming the expected behaviour I described above was correct), I only noticed the issue when I ran the new unit-tests on the CMM2.
