Local Time 02:13 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Option Base bug in MATH FFT ?
Posted: 08:24am 19 Sep 2021
Hi Peter,
Found this whilst working with Volhout's MATH test code:
> 480MHz Colour Maximite 2 G2
MMBasic Version 5.07.01RC2
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> list "fft_bug.bas"
Option Default None
Option Explicit
Const BASE% = Val(Mm.CmdLine$)
Option Base BASE%
Const NUM_SAMPLES% = 512
Dim sin_amp2!(NUM_SAMPLES% + BASE% - 1)
Dim dft!(2 + BASE% - 1, NUM_SAMPLES% + BASE% - 1)
Dim i%
For i% = BASE% to NUM_SAMPLES% + BASE% - 1
 sin_amp2!(i%) = 2 * Sin(2 * Pi * i% / NUM_SAMPLES%)
Next
Math Fft sin_amp2!(), dft!()
Print Math(Max dft!())
> run "fft_bug.bas", 1
511.9614473
> run "fft_bug.bas", 0
512
Assuming it's a thing (i.e. I haven't just confused the hell out of myself with Option Base) and you fix it could I please have an updated copy of the MATH source to integrate with MMB4L.
Thanks,
Edited 2021-09-19 18:33 by thwill
Posted: 09:02am 19 Sep 2021
I'll leave you to find the bug in your test program (HINT try comparing sin_amp2!() in both cases)
Posted: 09:04am 19 Sep 2021
  matherp said  I'll leave you to find the bug in your test program (HINT try comparing sin_amp2!() in both cases)
D'oh! Thanks Peter.
Posted: 09:12am 19 Sep 2021
If you look at the imaginary component of the entry with 511.9614473 it is 6.2830
take the square root of the sum of squares of both numbers and you get 512. Your error introduced a phase shift hence the difference and the non-zero imaginary component
Posted: 08:37am 20 Sep 2021
  matherp said  If you look at the imaginary component of the entry with 511.9614473 it is 6.2830
Thanks Peter.
I vaguely remember someone saying "Fourier Transform" in my first year of university, but for the remainder and the 20+ years since they have never reared their head in my career.
