Local Time 04:05 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LINUX: Equivalent of END TASK?
Posted: 05:45am 17 Aug 2021
When you have an application crash in Linux, is there a secret hotkey you can use to bring up the equivalent of Task Manager, where you can then kill the crashed application?
I have had this happen a few times when a Linux application crashes, but then I have no way to get rid of it off the screen.  Cos it has crashed, none of the buttons work, and you can't move the windows etc.
In the past, I have simply restarted the Linux box, but surely there is some method to kill a crashed application?
I'm not as afraid of the Linux console as I once was, so if I can do it that way, that would be OK too.
Posted: 07:09am 17 Aug 2021
Many versions of Linux X support multiple desktops (4 is common). Unless Linux its self has frozen, it may be possible to switch to another desktop and shut it down from there. Does not always work.
Many Linux variants allow for <ctrl>-t to bring up a terminal window. The "sudo su" to become root. Then list the tasks (I don't have a linux box here, so I have to check what command that is) and kill the one that has crashed by typing "kill nnnn". nnn is the PID of the task.
Posted: 07:35am 17 Aug 2021
You'll probably find that, from a command line:
either sudo su to become root
or use a temporary root as sudo <command>
The latter is popular on Raspberry Pi systems as the root level is normally disabled.
sudo top lists *everything* about every process
sudo ps  shows a more abbreviated form
You need the pid for the process that's being a pain in the proverbial then
kill <pid>
If you get the process name from the listing you can use
killall <process_name>
Yes, I cheated. I've not had a linux box running for a while so I had to refresh the old brain cells. :(  I did remember bits of it though. :)
https://www.linux.com/training-tutorials/how-kill-process-command-line/
Posted: 07:37am 17 Aug 2021
ps -aux to get the list of active tasks
sudo kill -9 task_number
Edited 2021-08-17 17:38 by matherp
cs41
Posted: 08:25am 17 Aug 2021
Another very  useful command to kill a stalled program is " xkill "
If you can bring up a terminal window, type xkill and press enter.
Then put the cursor on the offending program and enter
Usually that works...  just occasionally it's not enough so then probably will need a restart.
cs
Rado
Posted: 09:02am 17 Aug 2021
xkill is your tool of the choice. :)
Rado
Posted: 09:05am 17 Aug 2021
You can also run
xprop _NET_WM_PID
from a terminal, click on the window, and get PID of the application in terminal.
Then simply
kill -9 PID
to close it and hopefully not leave any zombie processes.
Posted: 12:32pm 17 Aug 2021
Hi Grogster,
I remember you are running Puppy Linux.
In Puppy Linux (I tested a few versions, not sure what you are running exactly) the generic way to open the task manager is the PC "Affengriff": <ctrl> <alt> <delete>.
Since you are ROOT in Puppy Linux, you can kill whatever you want immediately.
Success,
Edited 2021-08-17 22:32 by Volhout
LeoNicolas
Posted: 01:19pm 17 Aug 2021
Try this:
alt + F2 -> type xkill and press enter
Click on the frozen app
You can also define a new shortcut to open the System Monitor or run directly the xkill command.
I like to install the System Monitor plugin on my desktop. This plugin has a quick access to it.
For Gnome 3:
https://extensions.gnome.org/extension/120/system-monitor/
Bizzie
Posted: 11:07pm 17 Aug 2021
I don't like xkill!
Just nuked more than I wanted by clicking the wrong window!
I would use kill -9 <PID>
Rob White
LeoNicolas
Posted: 02:29am 18 Aug 2021
You can also use killall <process name>
Posted: 04:53am 18 Aug 2021
Lots of replies!
Thanks, chums.
I will try some of those out.
