Local Time 05:08 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : High Accuracy RTC? CMM2
mclout999
Posted: 07:30pm 04 Aug 2021
Hi all.  I got my GEN2 unit from https://micromite.org/  and it is very nicely made.  He has included the 2 resistors for the PS2 mouse function and it seems he has populated the High Accuracy RTC but when I issue the Option DS3231 command it returns "Invalid Command"  Not sure what is happening there.  If the chip is not functional is that why that command does not work?  Otherwise, did I miss some change on that function or any issues with it?  Thanks
PS. I am on Beta 4
Edited 2021-08-05 05:36 by mclout999
Posted: 08:30pm 04 Aug 2021
See the post "OPTION Errors".
Someone has what seems to be a similar problem, fixed by making OPTION DS3231 the last option set up.
Posted: 09:22pm 04 Aug 2021
OPTION DS3231 ON
You need the ON
It will cause a reboot
mclout999
Posted: 09:33pm 04 Aug 2021
Yes after OPTION RESET and the ON it works just fine.  I have got to reread the new user guide all the way through again.  I Just put it on my kindle.   It is very nice of Phil to include the chip. Thanks.
Edited 2021-08-05 12:24 by mclout999
