Local Time 06:05 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic and Bit Shifts.
vegipete
Posted: 03:13am 01 Aug 2021
What would you expect a bit shift by a negative number to do?
Would you expect, for example, 64 << -2 to be the same as 64 >> 2?
As it stands, bit shifting by a negative gives 0. Could that be changed?
(CMM2, but maybe others too.)
SimpleSafeName
Posted: 03:50am 01 Aug 2021
Would it be up to the user not to wrap around into negative territory, or does that matter?
Say 16 << -6 for example.
Posted: 03:53am 01 Aug 2021
  vegipete said  CMM2, but maybe others too.
Not on the Micromite.
  vegipete said  Could that be changed?
This is one for Peter but I suspect that it is a "feature" of the ARM architecture.
vegipete
Posted: 05:48am 01 Aug 2021
  SimpleSafeName said  Would it be up to the user not to wrap around into negative territory, or does that matter?
I'd say it's up the user to keep track of shift size. And said user better have a good idea what's going on if shifting negative integers.
There is the >>> operator which does treat negative integers sensibly. Although I haven't determined what it does with a negative shift amount.
The effect of <<< is slightly weird - maybe a left shift of nothing, followed by a less than comparison, giving a result of 0 or 1.
Posted: 07:28am 01 Aug 2021
  Quote  As it stands, bit shifting by a negative gives 0. Could that be changed?
The CMM2 code is identical to all other MMBasic implementations so this must be what the ARM H/W does
The only thing I could do is trap negative shifts as an error.
The difference between >> and >>> is described on page 56 of the 5.07.00 manual
<<< makes no sense and does not exist
Edited 2021-08-01 17:28 by matherp
vegipete
Posted: 06:15pm 01 Aug 2021
> ? 64 >> 2        ' #1
16
> ? 64 >>> 2       ' #2
16
> ? -64 >> 2       ' #3
4611686018427387888
> ? -64 >>> 2      ' #4
-16
> ? 64 >>> -2      ' #5
0
> ? -64 >>> -2     ' #6
-4294967296
> ? 16 << 2        ' #7
64
> ? 16 <<< 2       ' #8
0
> ? 1 << 6         ' #9
64
> ? 1 <<< 6        ' #10
1
#1 to #5 : as expected
#6       : don't know
#7, #9   : as expected
#8, #10  : parsing error?
My original question of whether n >> -s could be treated the same as n << s (and by extension, n << -r same as n >> r) comes about from some pixel/bit map shifting code I'm fiddling with. As it stands, I need different pieces of code for left and right shifts.
twofingers
Posted: 07:10pm 01 Aug 2021
  vegipete said
> ? 16 <<< 2       ' #8
0
> ? 1 << 6         ' #9
64
> ? 1 <<< 6        ' #10
1
@vegipete
Peter said:
  matherp said  <<< makes no sense and does not exist
Hmm. Do I miss something?
Michael
vegipete
Posted: 11:01pm 01 Aug 2021
<<< does not throw an error. Instead, it returns slightly unexplainable results. As a operator, it doesn't exist. But as 3 less than signs in a row, it does exist when perhaps it should be an error.
Posted: 11:12pm 01 Aug 2021
This is how the interpreter reads it:
> print 16 << < 2
0
> print 1 << < 6
1
It seems to skip over the << or treat it as 'x << 0' reducing the code to:
> print 16 < 2
0
> print 1 < 6
1
Not all errors get found by the interpreter.
Edited 2021-08-02 09:18 by TassyJim
