Local Time 06:07 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 sprite screen flickering
freemesy
Posted: 09:07am 27 Jul 2021
Hi to all forum members!
I've got problem with programming CMM2 (gen 1.). The main goal is to move a sprite beyond the background. Or at least move a sprite beyond another sprite. When the move accurs (with next-move or show commands) the screen is flickering. The sprites always redraw and that cause a very ugly flickering effect. Do you have any idea how to achive the goal, not to flicker? In fact when I use the 12-bit mode the flickering is more worse then in 8-bit or 16-bit mode. Some time ago I tried to write a scroll rutine in 12-bit mode but it has got the same problem. When blit occurs the screen was alwas flickering (no sprite in that). I tried the getscanline function to make the blit or sprite move occuring when the scanline is out of the way, but no success, same result.
Here's my code:
option default none
option explicit
const vstart=150
dim integer i,j,cpos=4,pl=0
               mode 1,12
               colour RGB(White),RGB(Black)
               cls
               page write 1
               box 180,120,440,440,1,RGB(Blue),RGB(Blue)
               for i=1 to 7
                   for j=1 to 7
                       circle j*60+160,i*60+100,25,1,1,RGB(Black),RGB(Black)
                   next j
               next i
               sprite read #1,180,120,441,441,1
               circle 400,80,25,1,1,RGB(yellow),RGB(yellow)
               circle 400,80,27,4,1,RGB(180,180,0)
               sprite read #2,373,53,55,55,1
               cls
               page write 0
               cls
               sprite show safe #2,cpos*60+180,vstart,0
               sprite show safe #1,170,120,0
waitforkey:
               if keydown(0)=0 then goto waitforkey
               if keydown(1)=27 then end
               if keydown(1)=32 then goto drop
               if keydown(1)=130 and cpos>0 then
                  cpos = cpos - 1
               endif
               if keydown(1)=131 and cpos<6 then
                  cpos = cpos + 1
               endif
               sprite next #2,cpos*60+180,vstart
               sprite move
               pause 150
               goto waitforkey
drop: .........
Thanks for your help, I hope somebody has got a godd idea.
Zoltan
vegipete
Posted: 06:59pm 27 Jul 2021
I think you are just trying to draw too much.
Nothing I've tried so far using sprites works cleanly - lots of tearing.
The following uses BLIT and is better, but is still not ideal. It might be better to draw all the changing parts on page 2, then do a "PAGE COPY 2,0,B" to transfer it into view.
Picking a lower resolution mode would help too.
option default none
option explicit
const vstart=100
const xoffset=193
mode 1,12
page write 1  ' create game board on page 1 - front (static) image
cls
for i=1 to 7
 for j=1 to 7
 next j
next i
page write 2  ' create disc image on page 2
cls
circle 27,27,25,1,1,RGB(yellow),RGB(yellow)
circle 27,27,27,4,1,RGB(180,180,0)
page write 0  ' draw disc on page 0 - background behind game board
cls
blit 0,0,cpos*60+xoffset,vstart,55,55,2  ' copy disc image at starting point
do
 if keydown(0)=  0 then continue do
 if keydown(1)= 27 then end
 if keydown(1)= 32 then exit do
   cpos = cpos - 1
 endif
   cpos = cpos + 1
 endif
 cls   ' erase everything
 blit 0,0,cpos*60+xoffset,vstart,55,55,2  ' draw disc in new position
 pause 150
loop
for i = vstart to 494 step 5  ' drop disc down screen
 do : loop until getscanline > 499 ' trial and error - not ideal
 box 190,100,420,460,0,RGB(Black),RGB(Black) ' erase previous - smaller area would be better
 blit 0,0,cpos*60+xoffset,i,55,55,2  ' draw disc in new location
 pause 2  ' brief pause so video catches up
next i
do : loop until inkey$ <> ""
Posted: 07:13am 28 Jul 2021
One big change would be to only redraw the sprite if it has moved.
freemesy
Posted: 07:39am 28 Jul 2021
Thanks for your replies.
Vegipete's advice and code was perfect. I learn from that so much.
It works like a charm.
Thank you for your effort to explain things for an "almost beginner".
capsikin
Posted: 02:23pm 28 Jul 2021
If I remember correctly my tile demo game here was able to move sprites around without flickering. It does it by calling the sprite move command right after a frame-blanking interrupt.
I do remember it was harder to get rid of the flicker at higher resolutions - at 640x400 I only updated the screen every second frame, whereas I might have been able to update every frame at a lower resolution.
12-bit modes (and higher resolution modes) use more memory bandwidth to read the screen memory while displaying it to the VGA port, that's probably why they flicker more.
