Local Time 07:06 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question on Color Mapping
William Leue
Posted: 06:15pm 14 Jul 2021
I am trying to figure out how to decompose a given color into its RGB components. The documentation is some help but I seem to be missing something.
For instance, in 8-bit mode, the documentation on the MODE command says that each pixel consists of an 8-bit byte, divided into two 3-bit fields for R and G, and the remaining 2-bit field for B.
So for instance, take the color white, which we know can be generated using rgb(255, 255, 255) or just rgb(white). If we assign this value to a normal 64-bit integer we get &HFFFFFFFF, as expected. Limiting this to just the least significant 8 bits we have &HFF.
My mental model says that each of the RGB field needs to be interpreted as equal to 255. (Of course this model is likely wrong.) But if the model is right, I can't figure out how those bitfields end up as 255's. Even shifting them to the most significant bits of an 8-bit value doesn't do it.
So I'm hoping that one of our gurus can help me grok this.
Thanks!
-Bill
William Leue
Posted: 06:17pm 14 Jul 2021
Of course I meant to say, "Given the hex value of a color and the current color bit depth, how do I decompose that into RGB values?"
-Bill
Posted: 06:20pm 14 Jul 2021
Not sure if it's significant, but Hex$(RGB(White)) and Hex$(RGB(255,255,255)) give FFFFFFF (7 x F), not the 8 x F that you report.
William Leue
Posted: 06:22pm 14 Jul 2021
Tom said,
  Quote  Not sure if it's significant, but Hex$(RGB(White)) and Hex$(RGB(255,255,255)) give FFFFFFF (7 x F), not the 8 x F that you report.
Yup, you are right, Tom. For this example it's not important.
-Bill
Posted: 08:10pm 14 Jul 2021
This thread might help, though it's 16-bit, not 8-bit.
Edited 2021-07-15 06:12 by lizby
William Leue
Posted: 08:13pm 14 Jul 2021
Thanks lizby, that is quite helpful!
-Bill
