Local Time 07:07 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Wi-Fi Commands?
toml_12953
Posted: 09:17am 14 Jul 2021
I have a CMM2 Gen 2 and have installed the ESP-01 Wi-Fi module in it. I looked through the manual but I don't see how to use it. Is it there somewhere and I just can't find it? If it's not there, where can I locate instructions?
Posted: 09:21am 14 Jul 2021
You do it the "hard" way, there may be better instructions elsewhere on TBS, but these are the ones I have bookmarked:
   https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=13414
Edited 2021-07-14 19:22 by thwill
Posted: 11:47am 14 Jul 2021
The original ESP8266 HTML server framework for AT commands was first published by Peter Mather here in 2016 (MM2: webserver with AT mode ESP8266).
(If that's what you're looking for.)
Edited 2021-07-14 21:48 by lizby
jirsoft
Posted: 11:58am 14 Jul 2021
I use with Napoleon Commander this FW
(it's more universal and can be easily extended)
Jiri
Posted: 12:25pm 14 Jul 2021
Jiri--with your firmware, is @http (sort of) equivalent to wget from a linux command line (or PC with wget.exe)?
Is there a way for the micromite to be an html server with that firmware?
Posted: 09:40pm 14 Jul 2021
On the CMM2 the internal ESP01 is connected to com2.
What you do with it is unlimited in options.
As well as Jiri's offering and the original AT command set there is ZiModem that is worth a look:
https://github.com/bozimmerman/Zimodem
jirsoft
Posted: 09:05am 15 Jul 2021
  lizby said  Jiri--with your firmware, is @http (sort of) equivalent to wget from a linux command line (or PC with wget.exe)?
The @http is simply streaming tcp data from web server to CMM2. For wget functionality you need mostly support on CMM2 side...
I tried it for example with telnet server on towel.blinkenlights.nl and it streams Star Wars as ASCII into CMM2
  lizby said  Is there a way for the micromite to be an html server with that firmware?
I didn't try it, but I think it could be done. When I save some time, I will test it...
Jiri
Posted: 12:14pm 15 Jul 2021
Thanks, Jiri. To me, the three main needed functions for an ESP-01 attached to a micromite are pass-through, wget, and html server. I haven't yet found that all in one. (But what am I missing?)
