Local Time 09:06 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI CALIBRATE info
panky
Posted: 01:55am 28 Jun 2021
Can anyone tell me what the five numeric fields reported by GUI CALIBRATE represent?
> gui calibrate
Done. No errors
Deviation X = 2, Y = 0 (pixels)
> option list
GUI CALIBRATE 0, 3966, 125, -898, 644
Doug
Posted: 04:10am 28 Jun 2021
Just a guess, ignoring the zero, perhaps they are decimal versions of the combined X-Y correction factors for the 4 targets. eg x = high byte Y = low byte of 2 byte number. Just speculation though.
Posted: 04:31am 28 Jun 2021
The numbers are correction factors used by MMBasic to translate the numbers generated by the touch controller chip into pixel coordinates.  They mean nothing outside of this.  For what it is worth they represent (in order of listing) Swap XY Coordinates if True, X Zero, Y Zero, X Scaling and Y Scaling.
The line
can be used to configure the touch on an LCD panel from within a BASIC program (see page 70 of the current Micromite User Manual.
panky
Posted: 05:03am 28 Jun 2021
Thanks Phil and Geoff,
Doug.
Posted: 09:23am 28 Jun 2021
I also was interested in this.
Thanks for the info.
Posted: 07:51pm 28 Jun 2021
If I make a note of the calibration values for a working lcd panel can I simply enter them when a new version of the software is loaded or when that panel is used again?
Edited 2021-06-29 17:58 by Mixtel90
Posted: 10:25pm 29 Jun 2021
Yes, just use GUI CALIBRATE at the command prompt.
I have found that the same calibration settings will work with most displays of the same type.
Posted: 05:49am 30 Jun 2021
Thanks, Geoff.  :)
