Local Time 09:07 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Algorithm Request: Comparison against a range that wraps
vegipete
Posted: 06:35pm 24 Jun 2021
Does anyone have or can figure out an _elegant_ algorithm for determining if two values are within a certain range of each other when the allowable range wraps around?
For example, suppose I want to know if two times are within 5 minutes of each other.
Say 12:30 and and 12:27.
"IF ABS(time1 - time2) < deltatime THEN true" works fine except...
it fails with, say, 12:58 and 1:02 (assuming a 12 hour clock.)
I have something with 5 IF statements, plus some MODs, which just strikes me as ugly.
Is there a better way?
Posted: 06:43pm 24 Jun 2021
Convert all times to seconds since a fixed point, do the calculation then convert back?
jirsoft
Posted: 07:27pm 24 Jun 2021
Is the difference between those 2 times 0:04 (12:58am, 1:02pm) or 11:56 (12:58pm, 1:02am)? You need to set the border conditions. But I'm not expert for 12 hour clock...
Jiri
vegipete
Posted: 09:23pm 24 Jun 2021
I only give time as an example. Compass direction in degrees is much the same. 359 degrees is very close to 1 degree. Or screen pixels, where the edges wrap to the other side.
I haven't come up with a simple criteria yet for when to 'unwrap' one of the limits. For example, with 359 degrees, you would subtract 360, giving -1, which _is_ close to 1.
Posted: 09:40pm 24 Jun 2021
You don't allow it to wrap round. :)
a = b*(1*(b<360))
Any use? Have I got the right idea?
a is always equal to b until b=360 then a=0
Posted: 09:48pm 24 Jun 2021
To determine the difference, you subtract a from b
To determine the difference in a case a wrap: add full range to b.
Then subtraxt
Then take modulus range
vegipete
Posted: 11:44pm 24 Jun 2021
Here's an example with degrees:
'target_angle' is where you want to be.
'current_angle' is where you are.
'tolerance' is whether you are close enough.
All angles are in degrees MOD 360, ie from 0 to 359.99whatever
angle_min = target_angle - tolerance
angle_max = target_angle + tolerance
if (angle_min < current_angle) AND (current_angle < target_max) then DoSomething
This won't work with wrapping.
Instead
if angle_min < 0 then
  if current_angle > angle_min+360 OR current_angle < angle_max then DoSomething
elseif angle_max >= 360 then
  if current_angle > angle_min OR current_angle < angle_max-360 then DoSomething
elseif angle_min < current_angle AND current_angle < angle_max then
  DoSomething
endif
works, but seems so convoluted and crazy. But maybe that's what is required.
Posted: 01:51am 25 Jun 2021
Vegipete's concept is the same as one I used for time, though different code and it works well. For angles another method is to convert numbers over 180 to negative. But only if they are within the "window" distance of 0 / 360.
Eg.
if (X > 180) AND (Y-window < 0)  then X = X - 360
if (Y > 180) AND (X-window < 0)  then Y = Y - 360
Then perform the tolerance window test.
Phil
Edit I think that's how it went, many years ago.
Edited 2021-06-25 12:02 by phil99
Posted: 05:08am 25 Jun 2021
The simplest is
diff = (new_angle-old_angle + 360) mod 360
You will have to decide if you want negative results or all positive. It depends on the usage.
MOD gives integer results so either multiply by 10 then MOD then divide by 10 etc or use another way to do MOD
dim float old_angle, new_angle, diff
do
input "both angles:", old_angle,new_angle
diff = (new_angle-old_angle + 360) mod 360 ' MOD gives integer results
print diff
diff = new_angle-old_angle + 360
if diff >= 360 then diff = diff - 360
print diff
print
loop
edit:
diff = (((new_angle-old_angle)*10 + 3600+1800) mod 3600)/10-180 ' 1 decimal place and negatives
Edited 2021-06-25 15:56 by TassyJim
Posted: 06:09am 25 Jun 2021
Found my old code fragment for compass. my previous post is messed up.
'window comparator
window=10 : x=356 : y=3
if (y>=360-window) and (x<window) then : y=y-360 :endif
if (x>=360-window) and (y<window) then : x=x-360 :endif
? abs(x-y)
if (abs(x-y) =< window) then : ?"within range" :else :? "No match" :endif
jirsoft
Posted: 08:22am 25 Jun 2021
I will prepare both values with MOD to  proper range 0-MAX, so you will have for example 2 values 0-359 for angle or 0:00-11:59 for 12-hour clock time.
Then if smallest difference
min(max(a,b)-min(a,b), WRAP+min(a,b)-max(a,b))
where WRAP is 360 for angle and 12:00 for time...
Jiri
Posted: 09:12am 25 Jun 2021
Two ways I use.
As already alluded-to, convert the times to unix/epoch time then compare (later MMBasics have Epoch time built in) but here is a Function  I use all the time on smaller Mites
If Abs(UnixTime(d1$)-UnixTime(d2$))<=300 Then...
... or (as already alluded-to) use DateDiff  (which uses UnixTime at its core) and the time period of your choice to do the same comparison
If Abs(DateDiff("m",d1$,d2$))<=5 Then ...
Neither of the above methods are fazed by the wrap around from 23:59 to 00:00
Edited 2021-06-25 19:17 by CaptainBoing
Posted: 09:54am 25 Jun 2021
Couldn't put it any more compact...
vegipete
Posted: 05:55pm 25 Jun 2021
There's some awesome ideas!
Jiri's version seems to be the hardest to break - I haven't been able to. I split it into 2 lines to simplify it slightly.
Phill's only works within the window. (Which suits my request.) His can't return an arbitrary difference.
TassyJim's only works 'forwards'. (359,1 is OK, 1,359 is not)
The neat thing is that all three have an underlying similarity. Plus they are more elegant than my brute force IF EVERYTHING method.
Thanks!
dim window = 10
do
print "Phill99"
if (new_angle >= 360-window) AND (old_angle < window) then new_angle = new_angle - 360
if (old_angle >= 360-window) AND (new_angle < window) then old_angle = old_angle - 360
diff = abs(new_angle - old_angle)
print diff
print
print "TassyJim"
print diff
print
print "Jiri"
diff = max(old_angle,new_angle)-min(old_angle,new_angle)
diff = min(diff, 360-diff)
print diff
print
loop
Edit: might be able to simplify Jiri's some more:
diff = abs(old_angle - new_angle)
Edited 2021-06-26 04:01 by vegipete
