Forum Index : Microcontroller and PC projects : projectf.io fpga-graphics
| epsilon Senior Member Joined: 30/07/2020 Location: BelgiumPosts: 255 |
I think some people here may find this interesting: https://projectf.io/posts/fpga-graphics/ There's MMBasic, then there's CSUBs, and then there's Verilog :-) Epsilon CMM2 projects |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9273 |
The video bit takes me back to the days of reading Don Lancaster's Cheap Video Cookbook. :) I looked for a *cheap* FPGA board for experimenting with not long ago. They are about as common as rocking horse poo. :( Mick Zilog Inside! nascom.info for Nascom & Gemini |
The Deca has all the bells and whistles (HDMI even) and costs only $37usd: https://www.arrow.com/en/products/deca/arrow-development-tools I think the Deca is a great option if you know what you're doing. For learning, Digilent's Arty A7 35T ($129usd) or the Go Board ($65usd) from NandLand.com are probably good options. Epsilon CMM2 projects |
The DECA looks interesting... Lol! Just glanced at the minimum spec for playing with it: Windows 7, 64-bit or Windows 8, 64-bit 4 GB RAM Minimum of i3 core I've never had an i-anything CPU in my life. Nothing so advanced. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
That's pretty hardcore, unless you mean you're using AMD Ryzen :-). Now I'm curious what you're using to browse this forum. I'm pretty cheap myself. I still take on freelance jobs to sponsor my hobbies, just like I did when I was 12. NandLand's Go Board is supported by an open source toolchain on Linux and OSX: http://www.clifford.at/icestorm/ Linux is supported on a wide range of devices, so maybe that's an option? Epsilon CMM2 projects |
hehe - It's a Celeron N3450 at 1.1GHz on each of the two cores. Win 10 64-bit. 4GB RAM (non-expandable). Completely fanless and not even warm. It works for most things, but it's no gaming machine. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
