Forum Index : Microcontroller and PC projects : New Version: Micromite MMBasic Ver 5.05.04
| Page 1 of 2 |
I have a new version of MMBasic for the Micromite, Micromite Plus and the Windows/DOS version. It is Ver 5.05.04 and you can download it from here: http://geoffg.net/micromite.html (scroll to the bottom of the page) This is a minor update that fixes some trivial but annoying bugs. Normally I wait for a serious issue to be fixed before releasing a new version but it has been almost a year since the last release and I thought it worth releasing this version to completely clear the bug list. Thankfully serious bugs are becoming increasingly rare. This version adds one new feature which will be appreciated by users who need to run the Micromite off a battery. Now the Micromite can run at a clock speed as low as 0.5MHz which reduces the power consumption to 1mA. This has a number of limitations so check the Manual and/or Change Log for the details. Geoff Geoff Graham - http://geoffg.net |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3420 |
Thanks Geoff, and all the other contributors, MMbasic is outstanding. Phil |
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1139 |
Having trouble unpacking files on 2 W10 computers. Mainly with the PDF's but also the HEX files. Unexpected error. ChopperP |
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2287 |
FYI No errors on my W10 PC NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Having trouble here also. I tried with Firefox and Edge and extracting with winrar and explorer. No joy with any combination. Jim VK7JH MMedit |
I just downloaded again and this time used the Windows file manager (normally don't use that) and clicked on the ZIP, everything is there and can be copied straight out as normal, Window 10-PRO 64, every current update including the one that adds the Stupid Weather and News feed icon on the task bar (removed). Strange? NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Same issue with W10 inbuilt zip tool. 7Zip also fails to extract same files, it appears to work but the files are zero bytes. |
FYI I've checked the unzipped pdf manuals, Hex and readme files, all are perfect. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
good work geoff i hope you have been keeping well!unfortunately am having the same problems as others with the archive being corrupt. using linux here, have tried clearing the browser cache. btw, do you maintain a list of past 'suggested additions'? i've made a few over the years - some have happened, others have not. it would be good to know (a) what once have been considered, (b) what ones have been included, and (c) what ones have been rejected. just to avoid making the same suggestions repeatedly. the last one i remember making, a year or so back, was for pulsein to be extended to collect a sequence of pulse lengths into an array for decoding wireless remote control signals. cheers, rob :-) |
@robert.rozee "the last one i remember making, a year or so back, was for pulsein to be extended to collect a sequence of pulse lengths into an array for decoding wireless remote control signals." That would also be useful for decoding the DHT11 temp & humidity sensor. There may be other devices that use variations of PWM encoding that could use it. MM50504 won't extract in Win XP either, so I don't think it's W10 problem. Phil |
| led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 210 |
DOS & Lite version zip - ok Full version zip - No good! Raspberry Pi led Miss you George |
(Using Linux) Full version reported bad after Documentation/Micromite Manual.pdf Lite & "DOS" are OK John |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9273 |
Thanks Geoff. :) Full version downloaded using the Vivaldi browser in Win10 no problem. Contents of zip appear to be ok. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| athlon1900 Regular Member Joined: 10/10/2019 Location: AustriaPosts: 51 |
Same issue here , Win7 Ultimate and WinRAR 5.70 .athlon1900 |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1784 |
No issues here (Win7 Ultimate, Winrar 3.9) Regards Michael PS: Many thanks Geoff! |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6209 |
W10 download (edge), extract -> errors Copy downloaded file to linux PC, Gnome Archive Manager -> error Extracted files : both hex files have size 0, docs in folders seem OK. @twofingers: did you check filesizes OK ? Volhout PicomiteVGA PETSCII ROBOTS |
I'm using 7-Zip 19.00(64) on WIN-10 Everything is perfect including all files and file sizes. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Just tried 7-Zip. Gave 0 byte files. ChopperP |
What version? I can read every PDF and read Every Hex file. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Well, this is interesting, I just downloaded the ZIP (full version) again, file sizes are all ok BUT some of the PDF and Hex files are now throwing an error WT? Error: Invalid size or checksum or unsupported compression format. File sizes are ok in the ZIP but extract to 0 bytes because the extraction never really completes with 7-Zip file manager. Strange that 2 pdf files are fine and 3 others aren't (Header Error) . Edited 2021-06-15 18:59 by KeepIS NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
| Page 1 of 2 |
