Local Time 11:21 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Schematic for E28 / Explore 28
MustardMan
Posted: 05:11am 01 Jun 2021
I am looking for a schematic for the Explore 28 (as sold by micromite.org & rictech.nz), but have not been able to find one.
I have found the 'LCD Backpack' schematic, but have found nothing on the Explore 28.
I have tried searching this forum, but for some reason I get a "fatal error" searching for 'explore28', nothing when I ask for 'e28' (the 'search' button does absolutely nothing) and lots of useless results from 'explore 28'.
Any pointers appreciated.
Thanks,
Posted: 05:22am 01 Jun 2021
Yep, I can help with that.
Standby.....
Here you go:
E-28 (1D) diagram.pdf
Edited 2021-06-01 15:25 by Grogster
MustardMan
Posted: 05:58am 01 Jun 2021
Thanks Grogster, you're a true champion!
MustardMan
Posted: 03:27am 02 Jun 2021
As an aside, the PIC32MX270F256 appears to be almost identical to the PIC32MX170F256, the latter being used in the Explore 28 board/s. The difference appears to be USB support and the loss of a couple of general I/O pins as a result.
With the current shortage of chips, the '170 is becoming hard to find. Will the interpreter run un-modified using a '270?
...I have a few '270s up my sleeve (although I also note they are becoming just as hard to find).
Cheers,
palcal
Posted: 03:52am 02 Jun 2021
Grogster may have some for sale, he sells the E-28.
If not I have one I can let you have, send me a PM ifyou want it.
Edit.  Just checked, RS Components and Element14 have them.
Edited 2021-06-02 13:59 by palcal
Posted: 04:55am 02 Jun 2021
To use the USB port use this version of MMbasic.
https://www.thebackshed.com/forum/uploads/kiiid/2017-06-20_094554_Micromite-MX270D.X.production.hex.zip
More info. on this page
https://www.thebackshed.com/forum/ViewTopic.php?TID=9358&PID=143940#143940
MustardMan
Posted: 06:08am 02 Jun 2021
@palcal
Thanks for the info on the suppliers. I am about to start a new design and the 28 pin PIC is a good choice. The 44 pin version chip is too big for my application. Although a little overkill (memory/speed), code testing & development with MMbasic is going to save me *SO* much time.
I have a couple of PIC chips (both types), but at present no Explore 28 board itself.
@phill99
Thanks for the tip on those downloads. I'm onto it!
EDIT: Looks like the code for the '270 version (both the PLCC44 & SO28) is quite old (2017). Won't affect me though.
Cheers,
Edited 2021-06-02 19:09 by MustardMan
Posted: 12:14pm 02 Jun 2021
  MustardMan said  As an aside, the PIC32MX270F256 appears to be almost identical to the PIC32MX170F256, the latter being used in the Explore 28 board/s. The difference appears to be USB support and the loss of a couple of general I/O pins as a result.
Yes, MMBasic will automatically detect the MX270 and adjust to run exactly the same (with two missing pins as you noted).
Turbo46
Posted: 09:33pm 02 Jun 2021
  Geoff said  MMBasic will automatically detect the MX270 and adjust to run exactly the same
I didn't know that. Can you use the USB as the console as well?
@MustardMan, Geoff wrote and article on the E28 for  Silicon Chip. They may have the bits to build one if you don't want to buy one from Grogster.
Posted: 09:47pm 02 Jun 2021
  Quote  I didn't know that. Can you use the USB as the console as well?
Not with standard MM2 firmware which already uses all flash available
Turbo46
Posted: 12:02am 03 Jun 2021
Thanks Peter, I thought that would be the answer but I had to ask.
MustardMan
Posted: 11:03am 03 Jun 2021
@Turbo46
Thanks - I ordered a few (prebuilt) from Rictech in NZ earlier today.
@Geoffg
Thanks for the concise answer, exactly what I was looking for.
