Local Time 12:20 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: XXTEA file encryption with 'spcrypt'
Posted: 03:09pm 31 May 2021
Hi folks,
I'm not sure why you'd want to, but with 'spcrypt' you can do XXTEA/CBC/PKCS#7 encryption/decryption of files - or at least that's what I'm saying it does until someone who knows more about encryption can tell me otherwise.
400MHz Colour Maximite 2
MMBasic Version 5.07.00b33
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> *cd sptools/src/spcrypt
> *spcrypt
spcrypt: no command specified
Usage *spcrypt [OPTION]... <command> "input file" ["output file"]
Options:
 -p, --password=<password>  Use <password> for encryption/decryption.
                            If omitted then user will be prompted.
 --version                  Output version information and exit.
Commands:
 decrypt  Decrypt "input file" using XXTEA algorithm.
 encrypt  Encrypt "input file" using XXTEA algorithm.
 md5      Calculate MD5 checksum for "input file".
> *spcrypt md5 spcrypt.bas
7ed827543e2e6cbb3aa00c19562dcb76
OK
> *spcrypt encrypt -p=wombat spcrypt.bas
Overwrite existing 'spcrypt.bas.encrypt' [y|N] ? y
Encrypting from 'spcrypt.bas' to 'spcrypt.bas.encrypt' ...
OK
> *spcrypt decrypt -p=wombat spcrypt.bas.encrypt
Overwrite existing 'spcrypt.bas.encrypt.decrypt' [y|N] ? y
Decrypting from 'spcrypt.bas.encrypt' to 'spcrypt.bas.encrypt.decrypt' ...
OK
spcrypt.zip
Notes:
1. This above .zip contains a "flattened" version of the source with all the dependencies (and some other random stuff it doesn't depend on) inlined, if you want to read the code I'd check my github repo for the original source instead:
   - https://github.com/thwill1000/sptools/blob/develop-r1b3/src/spcrypt/spcrypt.bas
   - https://github.com/thwill1000/sptools/blob/develop-r1b3/src/splib/crypt.inc
2. 'spcrypt' uses a random initialisation vector, so if you encrypt the same file twice you get two different output files, both of which should decrypt to the original file.
3. Whilst almost certainly "better" than any adhoc encryption this isn't on a par with AES-256. I'm using MD5 to convert a password to a 128-bit key, which isn't particularly recommended (https://en.wikipedia.org/wiki/MD5) and XXTEA is also not the most secure (https://en.wikipedia.org/wiki/XXTEA).
Edited 2021-06-01 01:11 by thwill
Posted: 07:30pm 31 May 2021
or this...
http://www.fruitoftheshed.com/MMBasic.RC4-Encryption-and-Decryption-Functions.ashx
Edited 2021-06-01 05:32 by CaptainBoing
Posted: 07:54pm 31 May 2021
  CaptainBoing said  or this...
Thanks Captain,
Indeed, I was aware of this implementation and it is undoubtedly faster but I would have learnt a great deal less. It's an obsolete stream cipher as opposed to an obsolete block cipher and the implementation provided doesn't have quite the bells and whistles supplied by spcrypt.
