Local Time 10:20 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Alpha Firmware
     Page 1 of 17
Posted: 11:18am 31 May 2021
I seem to have found a way round the flash issue so the Picomite is back on
Please find attached a3
PicomiteV5.07.00a3.zip
This now has working settick and watchdog + lots of CMM2 commands (MATH, SORT etc.). Next big job is to get permanent options working then I can start on I/O
Use LIST COMMANDS and LIST FUNCTION to see what is there
Known issues: PEEK and POKE there but not fully working
Please use this new thread for issues found, ideas etc.
Edited 2021-05-31 21:18 by matherp
Posted: 11:36am 31 May 2021
Great stuff Peter,
I wonder if it would save you time (and questions from uC ignoramus', i.e. me) if you could briefly summarise what your expectation is that the Picromite will not be able to do that the CMM2 can do, ignoring the obvious VGA output, USB keyboard support and performance differences.
Thanks,
Posted: 11:56am 31 May 2021
in a3:-
LIST COMMANDS:
AutoSave and Autosave both listed
Poke listed twice
Command codes have changed from a2. This may or may not matter but it messed up some progs I already had in flash.
SUB has become TROFF
PRINT has become RANDOMIZE
I don't know if there are others.
With the relevant changes my chain test still runs fine. And the light still flashes comfortingly. :)
Posted: 12:14pm 31 May 2021
  Quote  I wonder if it would save you time (and questions from uC ignoramus', i.e. me) if you could briefly summarise what your expectation is that the Picromite will not be able to do that the CMM2 can do,
The PicoMite is designed as an embedded processor like the normal Micromite not a computer
  Quote  Command codes have changed from a2
Yes this will happen with every new release until the command list settles down. The flash has the tokenised version stored. You need to reload from ascii source
Posted: 12:20pm 31 May 2021
Peter,
Not sure if it is me, but after programming a3, the board resets and starts up as /dev/ttyACM0. And I can use it. Great !!
But when I unplug the board, and insert it again, it does not enumerate as a serial port. Not in my W10 PC, not in my linux PC.
Maybe I have damaged my board. But it is repeatable. After programming it works, but coldboot it does not.
I'll investigate some more. MAybe it is the SD card wiring....
Posted: 12:21pm 31 May 2021
Yay.
LIST COMMANDS shows POKE twice, also AUTOSAVE. New are ?, AUTOSAVE, CASE, CASE ELSE, CAT, CPU, CSUB, DEFINEFONT, END CSUB, END DEFINEFONT, IRETURN, LONGSTRING, MATH, SETTICK, SORT, WATCHDOG.
LIST FUNCTIONS shows AS twice. New are DateTime$(, Day$(. Epoch(, LCompare(, LGetByte(, LGetStr$(, LInStr(, LLen(, MM.Info$(, MM.Watchdog, Peek(.
> ?mm.device$
RP2040 PicoMite
Edited 2021-05-31 22:25 by lizby
Posted: 12:28pm 31 May 2021
  Mixtel90 said  Command codes have changed from a2. This may or may not matter but it messed up some progs I already had in flash.
Can you explain what you're doing with the ordered list of commands within a program?
Posted: 12:33pm 31 May 2021
To the limitations of my understanding of micro-controllers I "understand", but those limitations are considerable and the differences between micro-controllers and micro-computers seem to be ever-decreasing ... isn't the CMM2 just a micro-controller with attitude ? However, nevermind, I'm sure someone will fill me in or I'll pick it up as we go along.
Given that the PicoMite has a file-system (or so I assume since it has SD support) could I request that you include * commands, OPTION SEARCH PATH, EXECUTE, and RUN with command line options as per the CMM2. This will allow my MMBasic unit-test suite to execute on it which is presumably advantageous to all ... except perhaps yourself given fixing any bugs it finds will ultimately fall to you.
Edited 2021-05-31 22:34 by thwill
Posted: 12:36pm 31 May 2021
  Volhout said  when I unplug the board, and insert it again, it does not enumerate as a serial port.
I'm also seeing this. Reflash (don't unplug afterwards) and it works--unplug and no flashing light and no com port.
Posted: 12:39pm 31 May 2021
As Peter said, the progs are stored in flash in tokenized form (not like the CMM2 where the SD files are in ASCII). He's messing with the command table (at the very least some commands will be being removed so that leaves holes) so the tokens will be changing. Reloading the prog in ASCII form re-tokenizes it correctly for the current MMBasic version. I was loading a2 tokenized files into a3 - which is doomed to failure. lol
Posted: 12:49pm 31 May 2021
  Mixtel90 said  I was loading a2 tokenized files into a3 - which is doomed to failure. lol
Ah. I somehow imagined that in a program you were executing commands indexed somehow.
So this means that until the command and function sets are stabilized, programs saved in flash may well not work after the PICO is flashed with new firmware. So saving to the SD (or on PC) and then after flashing, re-saving the programs to flash will be required (as Peter said, but I didn't understand the context).
Edited 2021-05-31 22:52 by lizby
Posted: 12:58pm 31 May 2021
That's it. I was being lazy.  :)
Posted: 01:06pm 31 May 2021
What are valid POKE (and PEEK) addresses which might be used for passing values between chained programs in flash?
Posted: 01:10pm 31 May 2021
Hi Peter,
Will try my other board tonight, but coldboot is definitely different with a3.
software a0 will connect my pi pico as COM13 to the W10 PC
software a3 will not connect to the W10 PC.
again, a3 works fine when the a3 software is copied, and the unit restarts automatically (also the blinking LED). But not after cold boot, not COM13, no blinking LED.
P.S. also tried after removing the SD card, and all wires. No change.
Edited 2021-05-31 23:29 by Volhout
Posted: 01:28pm 31 May 2021
FLASH CHAIN n just retains all variables automatically, apparently. No need to peek & poke.
I just tried disconnecting my Pico, waiting untill the com port disappeared and plugged in again. It connected correctly.
Incidentally, in FLASH CHAIN n, n can be a variable so you can have a nice easy menu system. :)
XMODEM SEND doesn't seem to be working yet. It wipes the prog in ram.
XMODEM RECEIVE works fine.
Posted: 01:32pm 31 May 2021
a4 - tidy up
PicomiteV5.07.00a4.zip
Includes the pin command but this just shows the mapping from GPn[n] syntax to pin numbers e.g. pin(GP28)=1 == pin(34)=1 == GP28pin=34:pin(GP28pin)=1
  Quote  Given that the PicoMite has a file-system (or so I assume since it has SD support) could I request that you include * commands, OPTION SEARCH PATH, EXECUTE, and RUN with command line options as per the CMM2.
Absolutely not and never - sorry
  Quote  I'm also seeing this. Reflash (don't unplug afterwards) and it works--unplug and no flashing light and no com port.
Works perfectly for me W10 + teraterm
Edited 2021-05-31 23:33 by matherp
Posted: 01:37pm 31 May 2021
Must be difference between boards...
OR difference between PC's.
I am also using Windows 10 and Teraterm.
Again, the behaviour of a0 is different. Maybe a non initialized vector, flag, of variable. Since enumerating can be the PC, but the LED blinking could be something else. The LED does not blink when I power the board from a charger. Is it related to USB communication ?
- in a3 function Timer gives an error.
- the blinking of the LED, could it be somewhat irregular ? Looks like the ON period is sometimes a bit longer. I will put a scope on it.
Edited 2021-05-31 23:47 by Volhout
Posted: 01:55pm 31 May 2021
  matherp said  Absolutely not and never - sorry
That's a shame, one command executed at the top-level runs every automated test I've written. Once you start unit-testing you never look back:
The FAIL is the known issue with STATIC variables that I've recently reported.
Anyway, thankyou for the PicoMite, it looks like a great piece of kit to release the magic smoke from whilst flashing LEDs, certainly cheaper than wrecking my CMM1 or 2.
Posted: 02:13pm 31 May 2021
re: USB not enumerating with power cycle
Still occurs for me with a4 using Win10 & Teraterm
  Volhout said  Must be difference between boards...
Posted: 02:18pm 31 May 2021
it may be useful to have FLASH ERASE ALL to make things a little easier when this happens.
do the flash slots have any sort of checksum applied? i'm thinking of a means of assuring that a slot isn't corrupted, for instance a bad write or if a pico has been used with MicroPython and the flash has all sorts of random data left behind.
rob   :-)
     Page 1 of 17
