Forum Index : Microcontroller and PC projects : CMM2 Expansion System
| siwypiotr Senior Member Joined: 18/08/2020 Location: PolandPosts: 127 |
![]() Dear Maximite Fans! I would like to present You new product, Maximite Expansion System. Expansion system for CMM2 was created to add easy to use expansion system for CMM2, expansions can be daisy chained, release Your creativity and try to find where is the limit! In next 2 days I will also release various expansion cards Schematic can be found here: schematic REV A v02 Instruction, code can be found on Github: CMM2 Expansion System Can be purchased here: CMM2 Expansion System ![]() 1. 2x20 IDC connector compatible with Maximite 2. 2x13 IDC additional connection for expansion system 3. Power supply selector and power supply daisy chain jumper 4. Power supply selector and power supply daisy chain jumper 5. Edge connector slots 6. 12V DC 2,5/5,5mm connector 7. Place for filtering capacitators (not included) |
Er, wrong URL for purchase I think. John |
Yes You are right, somehow there is no Edit button so I can not correct this. Here is correct link: https://sklep.pslabs.pl/Maximite-Expansion-System-p169 |
| romba6 Newbie Joined: 04/07/2020 Location: United KingdomPosts: 39 |
Are you still NOT shipping to the UK ? Edited 2021-05-31 04:25 by romba6 |
John Yes You are right, somehow there is no Edit button so I can not correct this. Here is correct link: https://sklep.pslabs.pl/Maximite-Expansion-System-p169 Are you still NOT shipping to the UK ? Unfortunately UK is the only country in whole world Im unable to deliver. |
Unfortunately UK is the only country in whole world Im unable to deliver. On the plus side https://youtu.be/4-tFsTN6lWY ![]() Best wishes, Tom Edited 2021-05-31 04:45 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Looks really cool Piotr and thanks for publishing the designs so that those of us in England-land (not a typo) can build our own using components sourced from Communist dictatorships. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Best wishes, Tom If You will be lucky to source the parts, it looks like there are shortages whatever I want to buy in PRC :) |
