Local Time 12:19 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Atari Joystick on Deluxe Edition CMM2
William Leue
Posted: 06:04pm 27 May 2021
I bought an clone version of the classic Atari joystick.
Plugging this into the joystick port of the Deluxe CMM2, I find that I can use the controller mouse open 2 to open it. (The controller classic and controller nunchuk do NOT work with this joystick.)
However, when I use functions like Mouse(X, 2), Mouse(Y, 2), Mouse(L, 2) and so on to try to detect joystick motions and button presses, I get nothing; just the default (400, 300) values for the center of the screen.
Is there some other function I should be using to work with the joystick?
Thanks!
-Bill
William Leue
Posted: 06:06pm 27 May 2021
Oh, I also noticed that the 3 nunchuk ports are mislabeled as to channel, as well as being upside-down.
The ports are labeled, left to right when looking at the front of the unit: 1, 2, 3. However, the actual port numbers are 3, 1, 2. Not a big problem of course.
-Bill
Posted: 09:54pm 27 May 2021
There is no built-in support for the Atari style joysticks.
You will have to roll your own.
William Leue
Posted: 04:29pm 28 May 2021
Ah, ok. I was hoping that Piotr had a little demo program he could share.
-Bill
