Local Time 04:05 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DHT11 Humidity Sensor on an F4 (or any MMBasic)
     Page 1 of 3
Andrew_G
Posted: 08:19am 25 May 2021
Do any of you have DHT11 (humidity) sensors running on an F4 (or MMBasic for that matter)?
I have my weather station sensors running on an F4.
The DHT22 works well but I would like to use the newer DHT11 (Jaycar's XC-4520).
I believe/understand that the same code should work for both the DHT22 and DHT11, ie page 97 of the manual:
  DIM FLOAT temp, humidity
  HUMID pin, temp, humidity
  PRINT "The temperature is" temp " and the humidity is" humidity
All I get from the DHT11 is the error value of 1000 for both temperature and humidity. The DHT22 is fine.
Both are running off 5V, no resistor, and I've tried various F4 pins (eg 15 and 97). There is a subtle difference in the pinouts but I believe I have that right.
Any ideas?
Andrew
Posted: 08:51am 25 May 2021
I have tried many times to get these things either
A. working
B. accurate - even ball-park
I have seen others report that they are at best an "estimator" and seem to fade with time.
I am done with them (and the dht22[?]) in favour of the I2C based HTU21D - much better device.
With projects that require temperature only, I have even "gone back" to using bead thermistors which are very good and surprisingly accurate within a given range.
The HTU21D software came from Tassy Jim, I think and the thermistor software I wrote myself after a couple of days research - you can find it here if you are interested in it. It's quite short and only requires the barest minimum of support circuitry and an analogue pin.
EDIT: Confirmed Tassy Jim as the source for the HTU21D software... as with so many things
https://www.thebackshed.com/forum/ViewTopic.php?TID=11937&PID=143600#143600
Edited 2021-05-25 20:56 by CaptainBoing
Posted: 10:12pm 25 May 2021
As far as I can tell, the only difference between the DHT22 and DTH11 is the start pulse.
The DHT11 needs a long 18mS start pulse compared to the 1mS on the DHT22.
That extra 17mS is a long time in micromite land...
and I would try with the 5k pullup resistor.
Andrew_G
Posted: 10:22pm 25 May 2021
Hi Jim,
This is part of a project with BigMik (watch this space . . ).
There is a 4K7 pullup {edit: - on Mik's board - I have tried it with and without the resistor}.
I'm only using the standard HUMID command - how do I increase the start pulse?
Hi to CaptainBoing too,
I will look at the HTU21D too but I'm keen to get the DHT11 going too.
Cheers,
Andrew
Edited 2021-05-26 08:24 by Andrew_G
palcal
Posted: 11:58pm 25 May 2021
I'm with the Captain, I never got the DHT11 to work the DHT22 was easy but they all failed after a while, probably not genuine and I could never find a 'definately genuine' one. The HTU21D all work and seem to be very accurate. I have an indoor and outdoor on my weather station and they have been running for about 2 years.
Posted: 12:09am 26 May 2021
Take the code from the source and bundle it into a cfunction with the start pulse increased as required.
I wouldn't like the source changed because that would have huge penalty on the performance for DTH22 users unless there was an extra parameter to indicate the DHT11.
I guess, with a bit of imagination you could tie two pins together.
The second pin configured as open collector and use it to pull the line low for 17.5 ms
17 ms after you start that pulse, start the HUMID command.
This assumes that the firmware isn't worried about the data line being low when the command starts. I haven't checked that.
It looks like there is a 'new' DHT11 but I don't think the start pulse time has changed.
https://www.seeedstudio.com/blog/2020/04/20/dht11-vs-dht22-am2302-which-temperature-humidity-sensor-should-you-use/
Andrew_G
Posted: 12:28am 26 May 2021
Thanks Palcal - I'll get a brace of HTU21D.
Jim, thanks too. I'm not into writing cfunctions but I will try the two-pin idea.
The good news of sorts is that I appear to have the "new" version (but that doesn't help it work)
Thanks,
Andrew
Posted: 01:21am 26 May 2021
You should be able to bit-bash it on the F4 using the ADC commands.
I might have a play (with a DHT22) when I get back from an appointment at the hospital.
palcal
Posted: 07:36am 26 May 2021
A brace, reminds me of when I was a boy and Mum would buy a brace of rabbits off the Rabbito who came around on his horse and cart.
Posted: 07:48am 26 May 2021
Being the son of a builder, my first thought was a 'brace and bit'.
Back to the issue, with further thought I think that the F4 can do a better job of reading the rogue DTH using interrupts and TIMER() to record the transitions.
We need to be able to find a 40uS difference between 0's and 1's
I will play (some time)
Andrew_G
Posted: 08:01am 26 May 2021
Thanks Jim,
"In the fulness of time" will be great but it has annoyed me that it says its the same but its not.
Cheers,
Andrew
(I remember the horse and cart milko, knife sharpener and bread men. The horses knew which houses to stop at which ones to skip.  Arrh, the good old days)
Posted: 08:38am 26 May 2021
Thought it would be clever to to try TassyJim's two pin method with one pin, but no go.
> for n=15 to 20 step 0.1 : SETPIN PE2, dout, oc, pu : pin(PE2)=0 : pause n : SETPIN PE2,off :HUMID PE2, temp, humidity :? n, temp, humidity :SETPIN PE2,off :next
15      1000    1000
15.1    1000    1000
15.2    1000    1000
15.3    1000    1000
15.4    1000    1000
15.5    1000    1000
15.6    1000    1000
15.7    1000    1000
15.8    1000    1000
15.9    1000    1000
16      1000    1000
16.1    1000    1000
16.2    1000    1000
16.3    1000    1000
16.4    1000    1000
16.5    1000    1000
16.6    1000    1000
16.7    1000    1000
16.8    1000    1000
16.9    1000    1000
17      1000    1000
17.1    1000    1000
17.2    1000    1000
17.3    1000    1000
17.4    1000    1000
17.5    1000    1000
17.6    1000    1000
17.7    1000    1000
17.8    1000    1000
17.9    1000    1000
18      1000    1000
18.1    1000    1000
18.2    1000    1000
18.3    1000    1000
18.4    1000    1000
18.5    1000    1000
18.6    1000    1000
18.7    1000    1000
18.8    1000    1000
18.9    1000    1000
19      1000    1000
19.1    1000    1000
19.2    1000    1000
19.3    1000    1000
19.4    1000    1000
19.5    1000    1000
19.6    1000    1000
19.7    1000    1000
19.8    1000    1000
19.9    1000    1000
Posted: 11:44am 26 May 2021
  phil99 said  Thought it would be clever to to try TassyJim's two pin method with one pin, but no go.
You have to start the long pulse as a background pulse and start the HUMID just before the long pulse ends.
Posted: 01:10pm 26 May 2021
Me thick, not get 2 pins work neither! Must be bed time.
SETPIN PE6,dout,oc,pu
for n=15 to 20 step 0.1 : pin(PE6)=1 : pause 200 : pulse PE6,n : HUMID PE2,temp,humidity :? n, temp, humidity : next
15      1000    1000
15.1    1000    1000
15.2    1000    1000
15.3    1000    1000
15.4    1000    1000
15.5    1000    1000
15.6    1000    1000
15.7    1000    1000
15.8    1000    1000
15.9    1000    1000
16      1000    1000
16.1    1000    1000
16.2    1000    1000
16.3    1000    1000
16.4    1000    1000
16.5    1000    1000
16.6    1000    1000
16.7    1000    1000
16.8    1000    1000
16.9    1000    1000
17      1000    1000
17.1    1000    1000
17.2    1000    1000
17.3    1000    1000
17.4    1000    1000
17.5    1000    1000
17.6    1000    1000
17.7    1000    1000
17.8    1000    1000
17.9    1000    1000
18      1000    1000
18.1    1000    1000
18.2    1000    1000
18.3    1000    1000
18.4    1000    1000
18.5    1000    1000
18.6    1000    1000
18.7    1000    1000
18.8    1000    1000
18.9    1000    1000
19      1000    1000
19.1    1000    1000
19.2    1000    1000
19.3    1000    1000
19.4    1000    1000
19.5    1000    1000
19.6    1000    1000
19.7    1000    1000
19.8    1000    1000
19.9    1000    1000
Posted: 10:03pm 26 May 2021
I don't think there is much point trying any times apart from 18mS
This is the sequence required (If it is going to work at all.)
  Quote    SETPIN PE6,DOUT,OC,pu
PIN(PE6)=1
PULSE PE6,18
PAUSE 17.5
DHT22 PE2,temp,humidity
 ? temp, humidity
The TEMP, HUMID command starts just before the pulse has ended. I am assuming that a 18mS pulse happens in the background - haven't checked that yet.
Provided interrupts are serviced fast enough, I think interrupt timing would be the way to go
Edited 2021-05-27 08:53 by TassyJim
Andrew_G
Posted: 11:23pm 26 May 2021
Sorry Jim but I can't get that to work (even with changing 'DH22' to 'HUMID').
My DHT22 took a few seconds to "warm up" so I've also tried it in a loop with 5 second delay between readings - still no joy.
Andrew
Posted: 01:37am 27 May 2021
"This is the sequence required (If it is going to work at all.)"
Yes, I forgot about the PAUSE 17.5 but still no joy with the DHT11. Also tried varying Pause from 17.1 to 17.9.
Posted: 02:25am 28 May 2021
Try this code.
You will need to set the pin number in line 5 and depending on what you are running it on, DHT22 may have to be changed to HUMID
 DIM FLOAT te, hu
 DIM FLOAT tr(50,2)
 DIM INTEGER steps, alldone
 DIM INTEGER dht_pin = 28
 DO
   DHT22 dht_pin,te,hu
   PRINT te,hu
   PAUSE 2000
   dht11 dht_pin,te,hu
   PRINT te,hu
   PRINT
   PAUSE 5000
 LOOP
SUB dht11 pn, tem, hum
 LOCAL INTEGER n, x = 1
 LOCAL INTEGER repl(5)
 LOCAL reply$
 steps = 0
 FOR n = 0 TO 50
 repl(n) = 0
 SETTICK 25, endtime,1
 PIN(pn) = 1
 SETPIN pn, DOUT, OC
 PAUSE 2
 PIN(pn) = 0
 PAUSE 18 ' this is the line that determines the start pulse length
 PIN(pn) = 1
 SETPIN pn, INTL, tick
 DO
 LOOP UNTIL alldone = 1
 SETTICK 0,1,1
 SETPIN pn, OFF
 FOR n = 1 TO 49
   IF tr(n+1,1)= 0 THEN EXIT FOR
   ' print  (tr(n+1,1)-tr(n,1))*1000, tr(n,1)
   IF (tr(n+1,1)-tr(n,1)) > 0.1 THEN
     reply$ = reply$ +"1"
   ELSE
     reply$ = reply$ + "0"
   ENDIF
 NEXT n
 FOR n = 0 TO 4
   repl(n) = VAL("&b"+MID$(reply$,n*8+x,8))
 NEXT n
 hum = repl(0)*256+repl(1)
 IF hum > 32767 THEN hum = hum - 65536
 hum = hum/10
 tem = repl(2)*256+repl(3)
 IF tem > 32767 THEN tem = tem - 65536
 tem = tem/10
 PRINT reply$
 PRINT repl(0),repl(1),repl(2),repl(3),repl(4)," ch_sum ";(repl(0)+repl(1)+repl(2)+repl(3)) AND 255
END SUB
SUB tick
 tr(steps,1) = TIMER
 steps = steps + 1
END SUB
SUB endtime
 alldone = 1
END SUB
Un-comment line 38 and post the table of values so I can see how reliable it will be.
So far I have only tested on a CMM2 and I have found the builtin command faulty. More work needed before reporting my findings to Peter.
Sunny day here today so back to pruning the fruit trees.
Andrew_G
Posted: 04:11am 28 May 2021
Hi Jim,
Thanks for that, much appreciated.
In SUB dht11:
- should "LOCAL INTEGER repl(5)" be ". . . repl(50)"?
- should there be a "NEXT n" after "repl(n) = 0" (MMEdit objects)?
Making those changes I get an output as below.
Cheers,
Andrew
run
1000 1000
0 2.945145e+06
0 2.945145e+06
0 2.945145e+06
0 2.945145e+06
0 2.945145e+06
1000 2.945145e+06
0 2.945146e+06
0 2.945146e+06
0 2.945146e+06
0 2.945146e+06
0 2.945146e+06
0 2.945146e+06
1000 2.945146e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
1000 2.945147e+06
0 2.945148e+06
0 2.945148e+06
0 2.945148e+06
0 2.945148e+06
0 2.945148e+06
00000100000010000000100000
4 8 8 0 0 ch_sum  20
204.8 103.2
1000 1000
0 2.945145e+06
0 2.945145e+06
0 2.945145e+06
0 2.945145e+06
0 2.945145e+06
1000 2.945145e+06
0 2.945146e+06
0 2.945146e+06
0 2.945146e+06
0 2.945146e+06
0 2.945146e+06
0 2.945146e+06
1000 2.945146e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
0 2.945147e+06
1000 2.945147e+06
0 2.945148e+06
0 2.945148e+06
0 2.945148e+06
0 2.945148e+06
0 2.945148e+06
4 8 8 0 0 ch_sum  20
204.8 103.2
Edited 2021-05-28 14:32 by Andrew_G
Posted: 05:43am 28 May 2021
  Quote  In SUB dht11:
NO. That array is for the 4 bytes plus checksum after converting the bits.
The bit timing is stored in tr()
Yes
the loop should actually be:
FOR n = 0 TO 50
   tr(n,1) = 0
   tr(n,2) = 0
 next n
There are a couple of other bugs in the version I posted but it is all pointless for now.
I just fired up my F4.
The manual suggests that TIMER function returns a float with microsecond resolution.
That appears to be wrong. On the F4, TIMER is in milliseconds only, no fraction.
That buggers up everything so back to the drawing board unless Peter can give us the higher resolution TIMER
The code works nicely on the CMM2 but I don't have any DHT11 to test.
I'm running MMBasic Version 5.07.00b9
Edited 2021-05-28 16:29 by TassyJim
     Page 1 of 3
