Local Time 13:27 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: MODs vs. WAVs, and ModTracker recommendations.
epsilon
Posted: 01:12pm 22 May 2021
I noticed that the PLAY WAV command is fairly expensive and it doesn't vary much with the sample rate:
> TIMER=0:PLAY WAV "fireSmall.wav":PRINT TIMER
13.444
> TIMER=0:PLAY WAV "fireBig.wav":PRINT TIMER
14.252
> list files "fire*.wav"
A:/XDRAGON/demo
12:54 22-05-2021      42982  fireBig.wav
12:55 22-05-2021      21514  fireSmall.wav
0 directories, 2 files
One is 22050Hz, the other 11025Hz.
I'm guessing file system access is a big part of the cost, and maybe that's not the case if I would use PLAY MODSAMPLE instead.
So I'm looking for a beginner friendly ModTracker for PC that allows me to edit in my sound FX (currently in .wav format). Any recommendations?
I found OpenMPT, but I'm struggling with it. It lets me import my sound effects but they sound weird. I see some resampling options, but those only made it worse.
Or maybe this approach is wrong and I should find a MOD archive somewhere that contains MOD friendly sounds?
Epsilon CMM2 projects
Tinine
Posted: 01:43pm 22 May 2021
Reaper DAW
No clue what this MOD thing is but when it comes to audio, Reaper can handle pretty much anything.
Edited 2021-05-22 23:44 by Tinine
epsilon
Posted: 02:02pm 22 May 2021
  Tinine said  Reaper DAW
...anything but mod files. .mod files are not recognized as supported media files.
MOD is a chiptune file format, late-80s/90s era. I think it came from Amiga but it was common in the PC demoscene as well.
Posted: 02:11pm 22 May 2021
  Quote  I noticed that the PLAY WAV command is fairly expensive and it doesn't vary much with the sample rate:
What do you think you are testing? Play WAV is non-blocking so you are just measuring the time to open the file and read the header + the first block of data. This won't vary much. The overhead of actually playing the sample will vary linearly with sample rate
Posted: 02:14pm 22 May 2021
MOD uses 8-bit PCM samples of instruments. Usually either 15 (IIRC) or 32. They did, indeed, start on the Amiga but PC sound cards started handling them too. I think the file specifies the instrument, special effect, channel, start and stop times. My memory is a bit hazy now. lol They were designed to have a low processing load on the system.
epsilon
Posted: 02:52pm 22 May 2021
Yes, I'm aware of that. But the time to open the file and reader the header and first block of data is already too much if the sound effect in question is a bullet being fired in a game for instance.
I'm hoping that PLAY MODSAMPLE will be faster because it's referencing samples in an already open MOD file. I would like to experiment with that a little, but haven't found a good ModTracker yet that allows me to add my sounds to an existing .mod.
Posted: 03:16pm 22 May 2021
If it is a short sound effect, load it into an array and use DAC START
epsilon
Posted: 03:20pm 22 May 2021
  epsilon said  I'm hoping that PLAY MODSAMPLE will be faster because it's referencing samples in an already open MOD file.
This indeed appears to be the case:
> play modfile "blind_justice.mod"
> TIMER=0: play modsample 26, 1: PRINT TIMER
0.007
The sample I played is the same as the .wav in the previous test.
(still struggling to get it to sound right however).
epsilon
Posted: 03:21pm 22 May 2021
  matherp said  If it is a short sound effect, load it into an array and use DAC START
Perfect! Yes, I'll try that. Thank you!
vegipete
Posted: 03:34pm 22 May 2021
Creating sounds with MODs
epsilon
Posted: 04:37pm 22 May 2021
  vegipete said  Creating sounds with MODs
Thank you. That's a great post! The steps outlined happened to match with what I was doing, but only in the case of 8000Hz the sample playback approached the original, at least when played back in OpenMPT itself.
Anyway, it's good to know OpenMT is the tool to use. I will experiment more with this.
epsilon
Posted: 12:42pm 23 May 2021
It was just a pilot error. The procedure as described by vegipete works great. So, MOD files are a great container for sound effects, and the PLAY MODFILE/MODSAMPLE API is a perfect API for sound effects in games: low overhead, easy to use, and supports overlapping sounds.
