Forum Index : Microcontroller and PC projects : F4: when is rgb(yellow) not rgb(yellow)?
On my F4 (IPS display, if it matters), I see the following: > ?hex$(rgb(yellow)) FFFF00 > pixel 700,110,rgb(yellow) > ?hex$(pixel(700,110)) F8FC00 Why aren't they the same? The same thing happens with CIRCLE and LINE. The problem that I have is that PIXEL(x,y) doesn't give me what appears to have been written with PIXEL x,y,somecolor (and I'm testing for a color match). This is with "ARMmite MMBasic Version 5.07.00b12" The same occurs on "ARMmite MMBasic Version 5.07.00b8" with an ili9341_16 LCD. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1159 |
All F4 display drivers use RGB565. So do an AND with F8FCF8 to see what your color really is. F4 H7FotSF4xGT |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3420 |
Ditto with "ARMmite MMBasic Version 5.07.00b12" and standard "OPTION LCDPANEL ILI9341_16, RLANDSCAPE" > cls &hFFFF00 > ? hex$(pixel(100,100)) F8FC00 > > cls &H00FFFF > ? hex$(pixel(100,100)) FCF8 > cls &HFF00FF > ? hex$(pixel(100,100)) F800F8 > cls &HFFFFFF > ? hex$(pixel(100,100)) F8FCF8 > Because it's RGB565 not RGB888 From the manual:- 16-bit interface to SSD1963, ILI9341 and OTM8009A Based LCD Displays The Armmite F4 drives the SSD1963 and some other 16-bit parallel bus LCD displays. For for extra speed the SSD1963 controllers run with a reduced colour range (65 thousand colours RGB565) compared to 16 million colours with the normal 8-bit interface. SPI touch is supported. The ILI9341 16 bit LCD that is purchased with the STM32F407VET6 development board, while only 320*240 pixels, plugs directly into the board via the 32 pin FSMC connector. All other LCD panels will require an adaptor board. |
Thanks, that explains it. In vegipete's CMM2 Renewed Defense of the Green Hills the bounding color of a circle is used to detect collision of an incoming missile with an explosion. On the F4, there was no match. I fixed it by beginning by writing a pixel of the desired color, reading it back and, and then doing the collision detection using that saved RGB565 version of the color. Yes, ANDing the color with &HF8FCF8 gives the right color on the F4. ~ Edited 2021-05-17 22:56 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
