Local Time 13:26 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Signed vs. unsigned right-shift
Posted: 11:04pm 15 May 2021
Hi folks,
I seem to recall we got a new >>> operator at some point during the 5.07 firmware betas but it isn't covered by the manual or the inbuilt MMBasic help yet. Can anyone point me back at the original post about it as my google-fu has failed me.
Related to this I think the signed and unsigned operators are the opposite way around to BBC Basic, that should make for some fun bugs if anyone does some porting. Alas even if that is true there isn't anything obvious that can be done without breaking old MMBasic programs
Edited 2021-05-16 09:10 by thwill
Turbo46
Posted: 11:48pm 15 May 2021
'ere 'tis
new operator for signed shift right
integervariable>>n' for unsigned shift right
integervariable>>>n' for signed shift right
Link
Posted: 02:53am 16 May 2021
The CMM2 manual has the description of >> incorrect
  Quote  For a right shift any bits introduced are set to the value of the top bit (bit 63). For a left shift any bits introduced are set to zero.
The micromite manual is correct.
DIM INTEGER x, y, z, w
x = 12345
y = x << 8
z = x >> 8
w = x >>> 8 ' not all versions have this operator
PRINT "x     = ";BIN$(x,64);" ";x
PRINT "x << 8= ";BIN$(y,64);" ";y
PRINT
PRINT "x >> 8= ";BIN$(z,64);" ";z
PRINT "x >>>8= ";BIN$(w,64);" ";w
PRINT
x = &h7FFFFFFFFFFF7F
y = x << 8
z = x >> 8
w = x >>> 8
y = x << 9
PRINT "x << 9= ";BIN$(y,64);" ";y
PRINT
PRINT
x = 0-&h7FFFFFFFFFFF7F
y = x << 8
z = x >> 8
w = x >>> 8
y = x << 9
PRINT
PRINT
'Output:
'x     = 0000000000000000000000000000000000000000000000000011000000111001  12345
'x << 8= 0000000000000000000000000000000000000000001100000011100100000000  3160320
'x >> 8= 0000000000000000000000000000000000000000000000000000000000110000  48
'x >>>8= 0000000000000000000000000000000000000000000000000000000000110000  48
'x     = 0000000001111111111111111111111111111111111111111111111101111111  36028797018963839
'x << 8= 0111111111111111111111111111111111111111111111110111111100000000  9223372036854742784
'x << 9= 1111111111111111111111111111111111111111111111101111111000000000 -66048
'x >> 8= 0000000000000000011111111111111111111111111111111111111111111111  140737488355327
'x >>>8= 0000000000000000011111111111111111111111111111111111111111111111  140737488355327
'x     = 1111111110000000000000000000000000000000000000000000000010000001 -36028797018963839
'x << 8= 1000000000000000000000000000000000000000000000001000000100000000 -9223372036854742784
'x << 9= 0000000000000000000000000000000000000000000000010000001000000000  66048
'x >> 8= 0000000011111111100000000000000000000000000000000000000000000000  71916856549572608
'x >>>8= 1111111111111111100000000000000000000000000000000000000000000000 -140737488355328
