Local Time 13:28 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sprite question or bug?
Goksteroo
Posted: 02:39am 13 May 2021
I'm in the middle of testing a few tests for animating sprites for a project and have come across 1 problem in coding. I am animating a sprite and the sprite animation is dependent on what direction it is moving - so we have 3 sprites each on 4 frames. Animation frame displayed is controlled by an interrupt routine and this seems to work fine. The issue I have found is in this little bit of code....
if x=oldx and (spr<5 or spr>8) then
sprite hide spr
spr=5
sprstart=5
sprmax=8
sprite show spr,x,y,1
endif
This causes a syntax error, but if I call the same code as a subroutine it works without an error.
if x=oldx and (spr<5 or spr>8) then front
sub front
sprite hide spr:spr=5:sprstart=5:sprmax=8:sprite show spr,x,y,1
end sub
Is there an issue in my code or just a quirk of using sprite commands in if/then statements?
Posted: 05:46am 13 May 2021
If you make the smallest (non-runnable but valid otherwise) program (or pair of programs) along those lines does it still cause a syntax error?
If it does, let Peter have it so he can debug MMBasic.
I suspect it will not cause the error...
Goksteroo
Posted: 06:59am 13 May 2021
Those pieces of code are taken from a working test program where the animation and sprites work.... as long as the second version using subs is used. BUT, I've just changed the code back to the original, non-sub version and now it works without any syntax errors. I've been trying to trouble shoot it for 2 hours this am 'til I turned the CMM2 off and posted here. Go figure - the joys of programming.
