Local Time 10:19 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Data retrieval using Seek,Input or whatever
Chrisk
Posted: 07:45am 11 May 2021
Hi guys
I need to be able to extract the time data from a file written to an SD card on my micromite 100.
The lines I use to write the file are:
open datafile$ FOR APPEND AS #1
print #1,GateCount,GateCountNow,Date$,Mid$(Time$,1,5)
The data has the format
1 1 02-02-2019 20:21
2 1 04-02-2019 07:21
3 2 04-02-2019 08:07
4 3 04-02-2019 13:55
5 4 04-02-2019 17:23
6 5 04-02-2019 18:11
I will then use this time info in the LCD display to show the last 6 gate openings.
I have looked at the info in the MMBasic language file but needless to say nothing I do seems to work.
Any suggestions
Chrisk
Posted: 07:58am 11 May 2021
If the fields have a fixed width then INPUT$() will do it for you.  Alternatively you could use LINE INPUT and pick the line apart with MID$().
jirsoft
Posted: 12:58pm 11 May 2021
Or LINE INPUT and then look with FIELD$ through spaces-separated fields...
Jiri
Posted: 09:04pm 11 May 2021
I think you are looking for the last 6 lines.
OPEN the file AS RANDOM (Normal AS INPUT may also work)
LOF() will give you the length of the file
SEEK LOF()-(22*6) will give you the start of the last 6 lines.
20 characters plus 2 bytes for crlf per line.
form there you can INPUT each line.
You may have to tweak the position you start reading from a little.
You could also keep a count of the number of times you add an entry and that will give you the starting point if LOF() isn't suitable.
It's a while since I did this in MMBasic so things might have changed a little.
Chrisk
Posted: 07:11am 12 May 2021
Thanks Guys I will have a go.
Chrisk
Posted: 07:29am 12 May 2021
It would help if you can format the data to keep the line length the same when the count gets above 9 (and 99)
jirsoft
Posted: 09:11am 12 May 2021
  TassyJim said  It would help if you can format the data to keep the line length the same when the count gets above 9 (and 99)
I expected missing it, so this was the reason I thought Chrisk will need LINE INPUT + FIELD$...
Jiri
Chrisk
Posted: 08:53am 20 May 2021
Further to the above.
I have these two files a gtest3.bas and the data file gtest3.txx
The program works with mmbasic but when I load them into my micromite there is no data (dat$) printout.
The data file consists of the date and times the gate device was triggered.The first two columns are just counters.
Any ideas guys
'gtest3.bas
'Works fine using mmbasic
'Note: First 9 records must have a space preceeding the digit
'to ensure uniform bytes in field.
cx = 24 'Characters per line plus cr + lf should be 22+2
x = 0
y = 0
open "gtest3.txx" for random as #3 ' gtest3 is data file
y = LOF(#3) ' Determines number of bytes in file
cb = y/cx  ' Number of lines in file
z = cint(cb)
do
i = LOF(#3) - y + (cx*x) '  Determine start of data location
seek #3, i ' points to start of data location
dat$ = INPUT$(cx, #3) ' now read next 24 bytes
x=x+1
if x =< z then   'count number of lines read
pause 100
print dat$
loop
else
endif
print
print "This is the end"
close #3
end
7 1 05-02-2019 08:21
8 1 06-02-2019 11:39
9 1 06-02-2019 15:22
10 1 07-02-2019 07:53
11 2 07-02-2019 13:06
12 3 07-02-2019 18:17
13 4 07-02-2019 22:33
14 1 07-02-2019 22:50
15 1 08-02-2019 08:21
16 2 08-02-2019 11:52
17 3 08-02-2019 16:37
18 4 08-02-2019 17:19
19 1 09-02-2019 08:10
20 2 09-02-2019 08:46
21 1 09-02-2019 19:42
22 1 10-02-2019 12:16
23 2 10-02-2019 12:22
24 1 11-02-2019 07:35
25 2 11-02-2019 07:51
26 3 11-02-2019 08:27
27 4 11-02-2019 10:43
28 5 11-02-2019 11:17
Posted: 12:59pm 20 May 2021
Your code is somewhat hard to follow without indentation, but it appears that you have a DO loop which contains an IF, but the ELSE and ENDIF are outside the loop. Who knows what MMBasic thinks you are trying to do.
Posted: 09:50pm 20 May 2021
  Quote    cx = 23 'Characters per line plus cr + lf should be 22+2 if more than 100 records
 x = 7
OPEN "gtest3.txt" FOR RANDOM AS #3 '  RANDOM or INPUT should be OK
 i = y -  (cx*x) -
1 '  Determine start of data location
SEEK #3, i ' points to start of data location
 'dat$ = INPUT$(cx, #3) ' now read next 24 bytes
 DO
LINE INPUT #3, dat$
PRINT dat$
LOOP UNTIL EOF(#3)
PRINT
PRINT "This is the end"
CLOSE #3
I would allow the extra byte on each line to cater for greater than 99 records.
An alternative is to go back a bit further and discard the first line you read which would be a partial line.
LINE INPUT will cover lines of any length.
If you want the order reversed, save them into an array then print in reverse order.
Chrisk
Posted: 10:15am 14 Jun 2021
Hi Guys
Just thought I would let you know that the problem I had with the SEEK instruction was due to MM version 5.0405.
With an upgrade (heavily supported by grogster) to 5.0503 the damn thing works.
Thought I would post this in case someone else has the same problem.
Chrisk
