Local Time 16:01 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WANTED: Type-I SRAM PCMCIA card, max 1MB
Posted: 03:47pm 04 May 2021
Hi folks,
Not really on topic but the denziens of TBS are the sort to have this kind of obsolete device sitting in a drawer. Happy to pay postage and beer money, you might get more selling it on eBay though.
Edited 2021-05-05 01:47 by thwill
Tinine
Posted: 12:49pm 05 May 2021
Hi Tom,
Well you just had me ransacking my "drawer of safe-keeping" because I use these cards in some of my Guitar pedals and what I was looking for is an adapter that I bought to accept modern SD cards.
I know I have it/them because I remember how impressed I was when I received them.
I'll have a look at the shop tomorrow.
Never had time to test but they are intended to substitute for a CF-1.
Craig
Posted: 12:59pm 05 May 2021
Thanks Craig,
The NC-100 notepad I need this for has a reputation for being very finicky regarding its memory card so I'm not sure an adapter to a modern solution is going to work ... or at least it's probably not something that I'm going to bet real money on.
Holger
Posted: 03:54pm 05 May 2021
I use the 1MB cards for Apple Newton in the NC-200c and NC-200. they work fine and are "kind of" easy to get
Posted: 04:10pm 05 May 2021
  Holger said  I use the 1MB cards for Apple Newton in the NC-200c and NC-200. they work fine and are "kind of" easy to get
Yes, I am aware of those cards and are the type I am looking for. I haven't found one easy to get though, are you making the mistake I often do of thinking something I did/got 10 years ago was recent
twofingers
Posted: 04:16pm 05 May 2021
  thwill said  ... are you making the mistake I often do of thinking something I did/got 10 years ago was recent
It's not?
Can you maybe post a picture?
Michael
Posted: 05:07pm 05 May 2021
  twofingers said  Can you maybe post a picture?
This is a Newton branded one, I think there were also 256K and 512K versions which might also suffice:
Apparently a 2 MB one will work too, you just tie two of the pins together so it thinks it is 1 MB.
It needs to be an older battery backed SRAM, I am given to understand (i.e. it may be codswallop) that the newer non-SRAM (?) types require some additional signal from the host device that the NC-100 (and -200) do not supply.
Tinine
Posted: 10:10pm 05 May 2021
That doesn't resemble the square devices that I am familiar with
Posted: 10:27pm 05 May 2021
  Tinine said  That doesn't resemble the square devices that I am familiar with
Sounds like you may have been thinking of Compact Flash (CF) cards? I believe this is an earlier technology.
Edited 2021-05-06 09:19 by thwill
