Local Time 20:54 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VT100 library for the Micromite console
Posted: 08:11am 23 Apr 2021
If anyone is interested, I put this together a while back and it's rather nice to have a bit of colour and Print@ to console displays. It's at it's most useful when loaded as a "fit & forget" library when it can, of course, run on a "headless" Micromite chip.
'These are MMBasic library routines for TeraTerm VT100 terminal video.
'Comments are NOT recoverable from the Micromite as they are stripped out on
'inclusion into the library. It is worth keeping a copy of this file. :)
' Vhelp          show help info
' Vcls           clear screen
' Vch            cursor home to top left
' Vcdn n         move cursor down n lines
' Vcr n          move cursor rignt n characters
' Vcl n          move cursor left n characters
' Vcup n         move cursor up n lines
' Vat row col    move cursor to row,column
' Vsc            save current cursor position
' Vrc            restore cursor position saved by Vsc
' Vbox y,x,w,h,t draw a box
' Vl y,x,l,t     draw a vertical or horixontal line to divide a box
' Vatt n$        set text attributes to n$ (none,bold,inverse,underlined)
' Vfc n$         set text/foreground colour by name or str$(number) 0-15
' Vbc n$         set background colour by name or str$(number) 0-16 (16 is light grey)
' ch             print Chr$(27)+"["  (the Escape sequence) - used internally
Sub Vcls 'clear the screen
ch
Print "2J";
Sub Vch  'cursor home to top left corner
ch
Print "H";
Sub Vcdn(n) 'move cursor down n lines
Local vz$
vz$=Str$(n)+";B"
ch
Print vz$;
Sub Vcup(n) 'move cursor up n lines
Local vz$
vz$=Str$(n)+";A"
ch
Print vz$;
Sub Vcr(n) 'move cursor right n characters
Local vz$
vz$=Str$(n)+";C"
ch
Print vz$;
Sub Vcl(n) 'move cursor left n characters
Local vz$
vz$=Str$(n)+";D"
ch
Print vz$;
Sub Vat(row,col) 'locate cursor to row,col
Local vz$
vz$=Str$(row)+";"+Str$(col)+"H"
ch
Print vz$;
Sub Vsc  'save current cursor position
ch
Print "7";
Sub Vrc  'restore cursor position saved with Vsc
ch
Print "8";
Sub Vbox(row,col,w,h,t) 'daw a box in "Terminal" font box chars
 Vat row,col
 If t=0 Then
  Print Chr$(218);String$(w-2,196);Chr$(191);
  Vat row+h,col
  Print Chr$(192);String$(w-2,196);Chr$(217);
  For i=1 To h-1
   Vat row+i,col:Print Chr$(179);
   Vat row+i,col+w-1:Print Chr$(179);
  Next
 Else
  Print Chr$(201);String$(w-2,205);Chr$(187);
  Vat row+h,col
  Print Chr$(200);String$(w-2,205);Chr$(188);
  For i=1 To h-1
   Vat row+i,col:Print Chr$(186);
   Vat row+i,col+w-1:Print Chr$(186);
  Next
 End If
Sub Vl(row,col,l,t) 'draw a vertical or horizontal line to divide a box
Local i,m
m=t:t=Abs(t)
If m>0 Then 'vertical line
 vat row,col: If t=0 Then Print Chr$(194); Else Print Chr$(203);
 vat row+l,col: If t=0 Then Print Chr$(193); Else Print Chr$(202);
 vat row+1,col
 For i=1 To l-1
  vat row+i,col
  If t=0 Then Print Chr$(179); Else Print Chr$(186);
 Next
Else  'horizontal line
 vat row,col
 If t=0 Then
   Print Chr$(195)String$(w-2,196)Chr$(180)
 Else
   Print Chr$(204)String$(w-2,205)Chr$(185)
 End If
End If
Sub Vatt(tatt$)  'set text attributes
ch
Select Case LCase$(tatt$)
Case "none"
Print "0m";
Case "b"
Print "1m";
Case "/b"
Print "22m";
Case "in"
Print "7m";
Case "/in"
Print "27m";
Case "u"
Print "4m";
Case "/u"
Print "24m";
End Select
Sub Vfc(color$)  'set text foreground colour
Local vz$        'if we have a colour number 0-15 then use it
If Len(color$)<3 And Val(color$)<16 Then
vz$="38;5;"+color$+"m"
ch
Print vz$
Else
ch
Select Case LCase$(color$)  'otherwise use the colour name
Case "black"
Print "30m";
Case "red"
Print "31m";
Case "green"
Print "32m";
Case "yellow"
Print "33m";
Case "blue"
Print "34m";
Case "magenta"
Print "35m";
Case "cyan"
Print "36m";
Case "white"
Print "37m";
Case "grey","gray"
Print "90m";
End Select
End If
Sub Vbc(color$)  'set text background colour
vz$="48;5;"+color$+"m"
ch
Print vz$
Else If Val(color$)=16 Then
vz$="48:2:115:115:115m"
ch
Print vz$
Else
ch
Case "black"
Print "40m";
Case "red"
Print "41m";
Case "green"
Print "42m";
Case "yellow"
Print "43m";
Case "blue"
Print "44m";
Case "magenta"
Print "45m";
Case "cyan"
Print "46m";
Case "white"
Print "47m";
Case "grey","gray"
Print "100m";
Case Else
Print "39m"; 'default background
End Select
End If
Sub Vhelp
Print
Print "      The V VT100 library"
Print
Print "Vcls            clear screen"
Print "Vch             cursor home to top left"
Print "Vcdn n          move cursor down n lines"
Print "Vcup n          move cursor up n lines"
Print "Vcr n           move cursor rignt n characters"
Print "Vcl n           move cursor left n characters"
Print "Vat row col     move cursor to row,column"
Print "Vsc             save current cursor position"
Print "Vrc             restore cursor position saved by Vsc"
Print "Vbox x,y,w,h,t  draw a box width w height h at x,y using 'Terminal' font box characters."
Print "                t=0 for single line, 1 for double"
Print "Vl y,x,l,t      draw a horizotal or vertical line to divide a box."
Print "                l is length, t=0 for single line, 1 for double, negative for horizontal"
Print "Vatt n$         set text attributes to n$ - none b /b in /in low u /u"
Print "                (none,bold,inverse,low_intensity,underlined)"
Print "Vfc n$          set text/foreground colour by name or str$(number) 0-15"
Print "Vbc n$          set background colour by name or str$(number) 0-16 (16 is light grey)"
Print "                Colours names are black, red, green, yellow, blue, magenta, cyan, white, grey"
Print "ch              print the Escape sequence 'Chr$27 [' - used internally"
Print
Sub ch
Print Chr$(27);"[";
Cyber
Posted: 05:33pm 23 Apr 2021
Nice! Thank you!
I thought of making similar thiggy, but did not get my hands to it.
Posted: 08:44am 24 Apr 2021
You're welcome. It was fun to write and I just hope it's useful to someone. :)
There's a couple of "yeah-but"s in it. It doesn't automatically insert crossing characters when lines cross in a box. That's left as mental exercise for the programmer. :)  There seems to be something a bit odd about text attributes IIRC (I've not used them much). It might be the way that Tera Term uses them as I think I have all the codes correct. Error checking is erm... lax, but that saves space in the library.
electricat
Posted: 02:30pm 06 May 2021
This is exactly I was thinking on yesterday and wrote few lines I needed, but you implemented so much more already, boxes colors... nice :D
So yes, it is useful :) Thank you.
My MMBasic 'sand box'
Posted: 01:34am 10 May 2021
Did you happen to write a test program for this? I'm looking to write a simplified VT100 terminal emulator for the F4 (for use as a debugging terminal for the CMM2) and would be happy to try testing it with someone else's code outputting VT100 sequences.
That program and your library might do will paired on either end of a set of micromites.
Posted: 06:36am 10 May 2021
Sorry, no. I wrote it in bits as I needed them and did a bit of testing at each stage. I've not done anything specific. Sloppy, I know, but it was only for me at the time. :)
All the testing I did was Micromite to Tera Term.
Edited 2021-05-10 16:38 by Mixtel90
electricat
Posted: 11:16am 22 Nov 2021
Hi, Mixtel90 and all
I wrote simple, universal i2C scanner. (PICOMITE MMBasic Ver 5.07.00)
All works ok, text formatting, terminal clear, returning cursor to home pos etc.
The problem I have - I am hiding cursor by sending [?25l
It works as expected.
But if for example one would brake program via ctrl+C, after returning to terminal, cursor is still hidden :D and if I would EDIT program, there is no cursor of course. I see in status line indications it is moving, but there is no cursor. I can return it by pressing in terminal window setup>OK but it is still somehow going roundabouts.
Do you have any ideas, how to deal on this, as if I would send [?25h e.i show cursor it still might happen not executed before ctrl+c and on returning to editor cursor would be hidden :D
How we could return cursor after program was interrupted? It seems to me as it would be firmware business already. But Im not too experenced in working with terminals so I might overlooked something:)
Posted: 11:20am 22 Nov 2021
Courtesy of @matherp, but any bugs are probably my fault:
' Change the break key.
Option Break 4
' On CTRL-C call my_exit().
On Key 3, my_exit()
Sub my_exit()
 ' Show cursor and clear console attributes.
 Print Chr$(27) "[?25h" Chr$(27) "[0m"
 ' Restore CTRL-C as the break key.
 Option Break 3
 ' End the program.
 End
Edited 2021-11-22 21:21 by thwill
Posted: 11:24am 22 Nov 2021
The best way isn't to use Ctrl-C to break the program! Change it to something else and include some sort of command to leave the program, doing all the necessary tidying up (setting sensible colours, switching the cursor on etc) before an END statement.
EDIT:
Beaten to it by Tom...  :(
Edited 2021-11-22 21:26 by Mixtel90
electricat
Posted: 02:35pm 22 Nov 2021
thwill YES!! Elegant solve!
Don`t be upset Mixtel90 :)
I will include nice message for user "Press Ctrl+C to exit" ;)
