Local Time 16:15 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Wrong Characters UART Communication with PICAXE
Vampire05
Posted: 09:01pm 22 Apr 2021
Hello People,
I need your help, please. I connected a PICAXE Microcontroller to a Micromite (or Computer) over UART. The Baudrate is 4800. When i send the String "1234abcd" on the PICAXE -> i receive the String "g3fO'N" on Micromite / Computer. The Only Character, that is received correctly is the "U".
Here is the PICAXE Code:
main:
sertxd("1234abcd")
pause 1000
goto main
The Baudrate must be correct, because the Terminal in the PICAXE Editor shows (at 4800 baud) the right Charecters.
Are there special UART options on the PICAXE?
Edited 2021-04-23 07:01 by Vampire05
Posted: 09:07pm 22 Apr 2021
It looks like your signal is inverted.
Posted: 09:09pm 22 Apr 2021
Typical PICAXE communication is "inverted"--idles opposite of what the micromite expects. Try
Serout pin#,T4800_4, ("1234abcd")
The "T" in T4800 stands for "True", i.e. non-inverted.
SERTXD will always be inverted.
Edited 2021-04-23 07:11 by lizby
Vampire05
Posted: 09:18pm 22 Apr 2021
Thats it:
Now it works.
Thank you very much guys!
