Forum Index : Microcontroller and PC projects : Armmite F4 - "Out of Memory": What would you expect from MEMORY cmd
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 910 |
Sorry to be such a PITA but . . . I'm running MMBasic 5.07.00b9 on my F4. I'm porting a program that runs on a MM170 to my ArmmiteF4. I keep getting an "Out of Memory" error on the F4. So I checked with a MEMORY command both within the program and in Console mode. Here is what I get with no program loaded (in fact it is just after I re-flashed it). memory Flash: 0K ( 0%) Program (0 lines) 132K (100%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 114K (100%) Free Wouldn't you expect more than 114k RAM free (the example in the manual shows 5470k). (And I've tried Key 1 at power-up and two different F4 boards.) Thanks, Andrew |
Manual is retaining the number for the CMM2--5470K. 114K is correct for the F4. This is what I get > ARMmite MMBasic Version 5.07.00b10 Copyright 2011-2020 Geoff Graham Copyright 2016-2020 Peter Mather > memory Flash: 17K (12%) Program (500 lines) 115K (88%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 114K (100%) Free > PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Lizby, Thank you so much for that. Very reassuring. I don't know why, but I keep on worrying that I have broken the poor little MMite. In fact my chip wastage is quite low. Now I can go looking for the reason the F4 is running out of memory. Cheers, Andrew |
Very strange! The line: Circle 602, 255, 154, 3,,RGB(red) causes an "Error : Not enough memory" within my spaghetti.With just the following snippet - after about 10 loops it errors out too: Memory do memory Circle 602, 255, 154, 3,,RGB(red) pause 10000 loop End It appears to be the line width of 3 causing the problem (a fix for me is to draw 3 circles). But this looks like a question for Peter? Cheers, Andrew (apologies to any who read this while I was editing it to add more information) Edited 2021-04-11 15:46 by Andrew_G |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3420 |
Same thing on the standard 320 x 240 LCD. do :memory :circle 160, 120, 100,5,1,rgb(green): loop gives:- Flash: 1K ( 1%) Program (15 lines) 131K (99%) Free RAM: 0K ( 0%) 0 Variables 55K (48%) General 59K (52%) Free Flash: 1K ( 1%) Program (15 lines) 131K (99%) Free RAM: 0K ( 0%) 0 Variables 61K (53%) General 53K (47%) Free Flash: 1K ( 1%) Program (15 lines) 131K (99%) Free RAM: 0K ( 0%) 0 Variables 68K (59%) General 46K (41%) Free . . . . . Flash: 1K ( 1%) Program (15 lines) 131K (99%) Free RAM: 0K ( 0%) 0 Variables 100K (88%) General 14K (12%) Free Flash: 1K ( 1%) Program (15 lines) 131K (99%) Free RAM: 0K ( 0%) 0 Variables 107K (93%) General 7K ( 7%) Free Flash: 1K ( 1%) Program (15 lines) 131K (99%) Free RAM: 0K ( 0%) 0 Variables 113K (99%) General 1K ( 1%) Free Error : Not enough memory > |
So its out of our league. (F4 or MMBasic?) How do we summon Peter when we need him. Is there a spotlight we can shine on a cloud in the UK? Cheers, Andrew |
Thanks for the report. Easy fix. Will post on main thread. |
Thanks Peter - I hope you don't mind being demeaned by a reference to Batman! You are a much more omnipresent superhero . . . Andrew |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9273 |
It is said that if you place a Microchip Backpack on the floor and walk round it 3 times while reading the Copyright section of the Micromite User Manual then HE will take on HIS earthly form. Or it might just be in my deranged imagination... :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
