Local Time 18:12 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can DI, DO be made available for F4 SPI2 pins as on CMM2?
Posted: 12:12pm 08 Apr 2021
On the CMM2, this works:
MMBasic Version 5.07.00b26
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> setpin 37,din: setpin 38,dout: setpin 40,dout
You can flash leds, etc.
But on the F4:
> ARMmite MMBasic Version 5.07.00b9
Copyright 2011-2020 Geoff Graham
Copyright 2016-2020 Peter Mather
> setpin 53,dout
Error : Pin | is reserved on startup
> setpin 52,dout
> setpin 54,dout
For compatibility, can the functionality be provided on the F4 or are there other reasons (interference with other functions) which prevent it?
Edited 2021-04-08 22:13 by lizby
Posted: 12:22pm 08 Apr 2021
They are available if you disable touch.
OPTION TOUCH DISABLE
Edited 2021-04-08 22:25 by matherp
Posted: 12:31pm 08 Apr 2021
  matherp said  They are available if you disable touch.
Ah, ok. I have an LCD on which touch has ceased working, so I can try it there.
Posted: 12:04am 09 Apr 2021
That worked, thank you.
Is the reason that SPI2 pins MOSI, MISO, and CLOCK (54/PB15, 53/PB14, and 52/PB13) cannot be accessed as Digital I/O pins when TOUCH is enabled because the touch pin (PB12) interferes with them, or they with it?
disco4now
Posted: 12:37am 09 Apr 2021
When Touch is enabled then SPI2 is also enabled, so it needs to reserve the pins. The touch chip on the LCD need to be queried using SPI2 to find out where the touch occurred. T_IRQ can only tell you its been touched. Disabling Touch will disable SPI2 and free up the pins unless its an SPI type LCD panel which also needs the SPI2.
F4 H7FotSF4xGT
Posted: 02:31am 09 Apr 2021
  disco4now said  When Touch is enabled then SPI2 is also enabled, so it needs to reserve the pins.
Ah, makes sense. Thanks. Too bad, though, that more complete compatibility with the CMM2 is not possible.
circuit
Posted: 06:36am 09 Apr 2021
  disco4now said  When Touch is enabled then SPI2 is also enabled, so it needs to reserve the pins. The touch chip on the LCD need to be queried using SPI2 to find out where the touch occurred. T_IRQ can only tell you its been touched. Disabling Touch will disable SPI2 and free up the pins unless its an SPI type LCD panel which also needs the SPI2.
A useful addition to the manual - perhaps with a short additional preamble explanation?
paceman
Posted: 10:56am 11 Apr 2021
Yes, I think that would be a good addition to the Manual too Gerry.
Greg
