Local Time 18:12 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Check for Nunchuk Controller
Archimedes5000
Posted: 09:48am 07 Apr 2021
Hello,
CMM2 V5.06 - is it possible to check the presence of a nunchuck controller without the program ending with an error?
Greetings Axel
Posted: 10:11am 07 Apr 2021
I've not used a nunchuck, but I'd attempt it by setting up a ON ERROR SKIP [nn] before a nunchuck command to read something, then check to see if the returned value is zero. If it is then there's no nunchuck.
Archimedes5000
Posted: 10:29am 07 Apr 2021
Hi, thank you!
By searching for "On Error skip" I found this
https://www.thebackshed.com/Forum/ViewTopic_mobile.php?TID=13475&P=1
Will try and be back later.
Greetings Axel
twofingers
Posted: 10:41am 07 Apr 2021
Please take a look at this example:
'Mandelbrot Explorer V1.3 for Color Maximite 2  9/20/2020
'By the Sasquatch
'Check for Wii Nunchuk
 On Error Skip 1
   Wii Nunchuk Open
 If MM.ERRNO = 0 Then
  If Nunchuk(T) = &HA4200000 Then  'Check for original style nunchuk
    HaveChuk = True
  Else
    Wii Nunchuk Close
  End If
 End If
 If Not HaveChuk Then
   'Check for Wii Classic Controller
   On Error Skip 1
     Wii Classic Open
    If Classic(T) = &HA4200101 Then  'Check for Classic
      HaveClassic = True
    Else
      Wii Classic Close
    End If
   End If
 End If
I used this for a short test:
TRUE=1
FALSE=Not TRUE
 On Error Skip 1
   Wii Nunchuk Open
 If MM.ERRNO = 0 Then HaveChuk = True
? HaveChuk
PRINT HEX$(NUNCHUK(T, 3))
do
PRINT "X-Joystick:"NUNCHUK(JX, 3)
PRINT "Y-Joystick:"NUNCHUK(JY, 3)
PRINT "Z-BUTTON   :"NUNCHUK(Z, 3)
PRINT "C-BUTTON   :"NUNCHUK(C, 3)
PRINT "X"NUNCHUK(AX, 3)-512
PRINT "Y"NUNCHUK(AY, 3)-512
PRINT "Z"NUNCHUK(AZ, 3)-512
PRINT NUNCHUK(AX0, 3)-512
PRINT NUNCHUK(AX1, 3)-684
PRINT NUNCHUK(AY0, 3)-512
PRINT NUNCHUK(AY1, 3)-684
PRINT NUNCHUK(AZ0, 3)-512
PRINT NUNCHUK(AZ1, 3)-684
pause 1000
loop
Michael
Archimedes5000
Posted: 03:52pm 10 Apr 2021
Please take a look at this great product. It has 3 nunchuk ports.
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=13673
So I have to find out whether and to which port a nunchuk is connected.
I will be back...
Greetings Axel
