Forum Index : Microcontroller and PC projects : CMM2 - Noobie to c=CMM2 question on basic
| Goksteroo Senior Member Joined: 15/03/2021 Location: AustraliaPosts: 114 |
I'm new to CMM2 and am digging my way into it's version of basic. I have done programming before on the Atari ST in STOS Basic and on the Amstrad CPC. My first project to learn the CMM2 is a maze generation program. All goes well until I want to control the movement of the player though a maze using the cursor keys. I'm using inkey$ to read for key presses but this is a real bottleneck and slows movement down quite a bit. Here is some test code I wrote after having issues with speed of this routine. mode 1,8 gui cursor load "mazist.cur":' simple 4,4 cursor sprite dim integer xx,yy,a,md xx=400:yy=300 gui cursor on 2,xx,yy 'settick 500,flsh: ' un-rem this for a flashing cursor do a=asc(inkey$): ' rem this line for rnd numbers for keys 'a=rnd*3+128: ' un-rem this for keyboard input 'for cc=1 to 20: ' un-rem this for keyboard input if a=130 and xx>100 then inc xx,-4 else if a=131 and xx<700then inc xx,4 else if a=128 and yy >100 then inc yy,-4 else if a=129 and yy<500 then inc yy,4 endif gui cursor xx,yy 'pause 5:next cc: ' un-rem this for keyboard input loop until a=32 settick 0,flsh end sub flsh inc md if (md mod 2)=1 then gui cursor show else gui cursor hide endif end sub The mazist.cur file is just a 4x4 sprite definition file. 4,4,0,0 4444 4444 4444 4444 Using this piece of code the cursor crawls around the screen. If I REM out the inkey$ routines and un-REM the random movement code, the cursor flies around the screen. In Amstrad basic I used an INKEY routine that interrogated a particular key and was very fast at doing so. Have I missed a more appropriate keyboard command? or have I just written poor code? The Maximite is running the latest beta firmware. Thanks, Geoff |
| RetroJoe Senior Member Joined: 06/08/2020 Location: CanadaPosts: 290 |
Welcome, Geoff, to the wonderful hobby of "Maximiting" I believe KEYDOWN () will do the trick. Enjoy Every Sandwich / Joe P. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9274 |
KEYDOWN is definitely quicker. Use KEYDOWN(1) because you are looking for one character It returns a numeric value. <- 130 -> 131 ^ 128 v 129 no key pressed = 0 Have fun. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
By using INKEY$, you are limited to the keyboard repeat rate. (Use OPTION KEYBOARD REPEAT <delay>,<rate> to set a faster repeat rate. The lowest value for <rate> is 25, meaning 25 ms between keys.) As the others have posted, KEYDOWN() would let your program check if a key is held down, without waiting for a repeat. Plus you can check for multiple (to some degree) presses, as well as modifiers. Visit Vegipete's *Mite Library for cool programs. |
Geoff, definitely read up on KEYDOWN as it does a ton of stuff, arguably everything you would ever need to capture user input from the keyboard.. FYI, that CMM Fun site is a relatively recent gift to the Maximite community from Jiri, who has also been banging out some awesome developer utilities, and the online MMBasic reference is courtesy of "Tassy Jim" Hiley, the author of "MM Edit" that allows you to develop code on your PC or Mac and download it to your CMM2 (versus using its built-in keyboard and VGA). If you go the "standalone" route, mouse support was recently added to the CMM2 firmware by Peter M., and makes using the built-in editor a whole lot more enjoyable. Depending on what "model" of mouse and CMM2 you have, interfacing the mouse can take different paths. There is a forum thread that explains it. I guess it goes without saying that just about everything that goes on here is a labor of love :) Happy Maximiting! Edited 2021-03-27 05:24 by RetroJoe Enjoy Every Sandwich / Joe P. |
If anyone would like it, here's the first CMM2 utility that did. It shows you the ASC codes in decimal and hex for most of the sensible characters. :) 'just an ASCII test file mode 1 cls dim dx(120),dy(120) x=20:y=20 for I=32 to 137 ? @(x,y)i @(x+50)hex$(i,2) @(x+80)chr$(i) dx(i-32)=x dy(i-32)=y x=x+120 if x>620 then x=20:y=y+30 next ?@(2,550)"Press key to show code" do a=keydown(1) if a>=32 and a<138 and f=0 then p=a-32 b=a colour rgb(0,0,0),rgb(255,255,0) ?@(dx(p),dy(p)) a @(dx(p)+50)hex$(a,2) @(dx(p)+80)chr$(a) f=1 end if if a=0 and f=1 then colour rgb(255,255,255),rgb(0,0,0) ?@(dx(p),dy(p)) b @(dx(p)+50)hex$(b,2) @(dx(p)+80)chr$(b) f=0 end if loop Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thanks guys, don't know how I missed KEYDOWN!! One question on it and the use of KEYDOWN(7) to test for the modifier keys. It returns values as expected for L and R shift but also changes the values (adds 32 like shift would with any other letter) returned with KEYDOWN(1) for the Down and Right arrow keys. The Left and Up values are not affected. Other modifier keys (Ctrl and Alt) do not change these values. I can get around this by changing to the Alt or Ctrl keys in my programme but am curious as to why this occurs. Oddly the Delete key also produces a Shifted character. Geoff Edited 2021-03-27 10:15 by Goksteroo |
