Local Time 20:18 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Wi-Fi Interface module...
Zonker
Posted: 12:00pm 22 Mar 2021
Morning folks...
I was wanting to try playing with decoding some Ethernet packets and wondering if anyone has any suggestions about a good module to use...
I found 2 of them... One for the E-100 - MIKROE-971 and should just "plug in"
The MIKROE-971 from Digi-key is $24... A bit pricey...
I also found one on AliExpress for $2.61..
They are both using the ENC28J60 Wi-Fi controller IC and use the SPI buss
Anyway... I just wanted to know if anyone has done any work or tested the module...
Thanks for any feedback...
Tinine
Posted: 12:16pm 22 Mar 2021
I have a few Click boards for the E-100 and it's a great way to go for development because there is usually sample code in their "Libstock".
The file extension is something like "mpkg" but all you need to do is unzip it.
