Local Time 21:34 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New CMM2. Keyboard not working if SD card plugged in.
Posted: 05:15pm 13 Mar 2021
As it says really...
No battery fitted. Date & time setup always works, whether SD card is fitted or not.
Without SD card I see the Check Disk error, but not when it's installed.
Without SD card I can input normal commands & run a For/Next loop on a line.
Display is good, no problems there (at this stage anyway!).
SD cards (same problem with all of them):
4GB Transcend SDHC FAT32 blank
8GB Toshiba SDHC I class 10 FAT32 blank
8GB micro-SDHC I FAT32 blank in an adaptor
Soldering on SD card socket *looks* ok. There seems to be connection between the PCB pad and high up on all the socket connections along the back.
Anyone got any ideas?
Posted: 05:21pm 13 Mar 2021
Measure the 5V rail with and without the SCcard plugged in and if not solid 5V then try a different power supply.
Details of which version CMM2 would be helpful
Edited 2021-03-14 03:22 by matherp
Posted: 06:03pm 13 Mar 2021
Thanks very much. Peter. The supply was the problem. Swapped the supply and also found a shorter lead. Bang on 5V now and it seems to be working ok now. :)
