Local Time 22:45 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 variable types in SUBs and FUNCTONs
jirsoft
Posted: 01:31pm 06 Mar 2021
is there any reason, why variable types in SUBs or FUNCTIONs can't be decalred by type before variable?
SUB test(INTEGER a, b)
END SUB
I know it's possible
SUB test(a%, b%)
END SUB
or
SUB test(a AS INTEGER, b AS INTEGER)
END SUB
But I'm using usually DIM INTEGER a, b because:
1. I can assign the value or values
DI INTEGER a = 3, b = 5
2. can be more variables of same type in one declaration
So right now I'm mixing because of it 2 different approaches in FUNCTIONs/SUBs and anywhere else...
Jiri
Posted: 02:17pm 06 Mar 2021
  Quote  is there any reason, why variable types in SUBs or FUNCTIONs can't be decalred by type before variable?
Can everyone stop challenging core MMBasic syntax - it is not going to change.
In this case the parsing would be difficult as subroutines can have different types for different parameters so you would have to keep context until the next type - not something which is or will be supported
If your program is predominantly integer then use OPTION DEFAULT INTEGER
Edited 2021-03-07 00:17 by matherp
jirsoft
Posted: 03:34pm 06 Mar 2021
Hi Peter,
it was not meant as offence, I have just asked the question. For me was strange, that in DIM I have 3 ways and in SUBs/FUNCTIONs just 2, so I have thought it's some mistake (if they were just the same 2 in DIM, I wouldn't asked).
So clear answer and I'm OK with it.
Jiri
