Local Time 22:47 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic: Setting Array Elements
vegipete
Posted: 05:26am 06 Mar 2021
The statement
DIM arry(2)=(16,17,21)
is valid.
Is there any reason why
arry()=(17,17,11)
couldn't also be valid, or is that just too perverse?
Posted: 08:24am 06 Mar 2021
  Quote  or is that just too perverse?
Not perverse but not implemented and won't be
Posted: 10:31am 06 Mar 2021
  vegipete said  The statement
is valid.
arry()=(17,17,11)
Think what extra work would be required to recognise (parse) that :(
As it starts out, it looks like a function call to arry.  If it's not seen the name arry before it adds it to the internal data structures as a function.  Then it finds the "=" and ... yuck.
jirsoft
Posted: 01:22pm 06 Mar 2021
is valid.
arry()=(17,17,11)
I know, it's not exactly the same, but I have already used:
OPTION BASE 0
OPTION DEFAULT NONE
OPTION EXPLICIT
DIM INTEGER arry(2) = (16,17,21)
printA(arry())
setA(arry(), "17,17,11")
printA(arry())
END
SUB printA(q() AS INTEGER)
 LOCAL INTEGER i, b = BOUND(q())
 FOR i = 0 TO b
   ?q(i),
 NEXT i
END SUB
SUB setA(q() AS INTEGER, nq AS STRING)
 LOCAL STRING nv
 LOCAL INTEGER i
 FOR i = 0 TO BOUND(q())
   nv = FIELD$(nq, i+1, ",")
   IF nv <> "" THEN
     q(i) = VAL(nv)
   ELSE
     ERROR "Not enough values"
   ENDIF
 NEXT i
END SUB
Jiri
vegipete
Posted: 05:39pm 06 Mar 2021
  matherp said  Not perverse but not implemented and won't be
That's OK.
The following works as a straight forward enough substitute:
a = 16 : b = 17 : c = 18
dim arry(2)=(a,b,c)
<some time later...>
erase arry() : dim arry(2)=(c,b,a)
The only nuisance is that you can't erase a variable that hasn't previously been dimmed into existence.
In my case, I need to re-initialize starting values in the array, so I can use constant values, instead of variables:
dim arry(2)=(1,2,3)
Edited 2021-03-07 04:07 by vegipete
