Local Time 22:46 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Smaller 20mhz X-tal...
Zonker
Posted: 02:47pm 04 Mar 2021
Morning fine folks...
I am trying to layout a new PCB that will use the PIC32-470 MCU...
In the design, I wanted to try to use a smaller package X-tal than the normal oblong metal can type... Was wondering if this type would work OK... I am not an expert at this by any means and was looking for any advice on a possible selection...
20mhz Crystal - ABM8G.zip
Much thanks...
Posted: 10:03pm 04 Mar 2021
I don't see any reason why not.
The PDF does say that you can specify in the part number, the load caps you plan to use, so I would be going for something like this one:
LINK
You would need to use 18pF caps instead of the 22pF used with the big crystal, but other then that, it should work perfectly.
Naturally, I have not tested this myself, but there is no reason why it should not work.  I have not looked at the frequency stability/tolerance vs the big crystal, but they are probably within a cat's whisker of each other.
EDIT: Make link clickable.
EDIT: Just checked the data for the TXC crystals I used in the MM+ stuff, and they have a frequency stability AND tolerance of +/-30ppm, so the Abracon crystal should be just about a perfect replacement for the through-hole one.  The TXC crystals state 18pF load caps too, but I have been using 22pF on every board ever made, and never had an issue.
Edited 2021-03-05 08:31 by Grogster
