Local Time 23:46 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - Thermal Printer
Nimue
Posted: 11:15am 28 Feb 2021
Morning all
As part of my ongoing "classroom monitor" we now want to add a cheap thermal printer -- possibly to capture sensor readings on an hourly basis (student idea).
Having poked around TheShed and other forums, these https://www.aliexpress.com/item/4000670706301.html?spm=a2g0o.productlist.0.0.1bd63eabVtoWWy&algo_pvid=8f88d204-b836-46e1-bf84-8d0d5f70dfd8&algo_expid=8f88d204-b836-46e1-bf84-8d0d5f70dfd8-0&btsid=2100bdd716145105558498323ee1d8&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_   seem to be the goto variety.
Qs:
(1) This is available in TTL or RS232 -->  Presumably TTL is the way forward.
Having poked around TheShed, there is reference to CSUBs or OPEN compspec$ as #1  and then printing directly to the printer  (granted you need to send some control chrs to the printer first).
Has anyone got one of these working connected to CMM2?
N
jirsoft
Posted: 05:34pm 28 Feb 2021
When you will get user guide with all control codes, then should be no problem to print. But first I would try to communicate with Chinese about this...
Jiri
Posted: 08:46pm 28 Feb 2021
This might help you.
It seems to be the protocol used and is possibly the same printer:
https://www.sparkfun.com/datasheets/Components/General/Driver%20board.pdf
Posted: 09:20pm 28 Feb 2021
If it really does "Support ESC/POS print instruction set", it might do bar codes.
I have a barcode printer sitting in the shed. I think it cost me about $3000 20+ years ago. It has printed a lot of labels.
Posted: 09:36pm 28 Feb 2021
some considerations... http://www.fruitoftheshed.com/Platform%20Agnostic.Simple-and-Cheap-way-to-add-a-Printer-to-your-project.ashx
Posted: 01:02am 01 Mar 2021
I've used these printers on a few projects.  They seem to work fine.  Best performance was at about 7v, but they suck a bit of current while printing - anything up to 2A depending on how dense the print is, so make sure you have a good regulated PSU module feeding the printer separate from the CMM2.  DO NOT connect to the CMM2 5v supply!
I have not tried these printers on the CMM2 specifically, but I have used them on the MM2 and MM+ chips.  The default baud-rate is 19k2.  TTL is the one you want - you can connect directly to the MM2/MM+/CMM2 com port.  In my case, I actually used the SerialTx Cfunction available as part of the firmware download.
You can change the font in them with some software.  I set mine up to the common DOS font CP427?  I forget the exact reference now - it was a few years ago, but I can hunt that information out if you want it.
CircuitGizmos
Posted: 04:21pm 01 Mar 2021
I really have to resist the urge to buy one of these just to have it.
