Local Time 00:44 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : xFind String Find across Files for CMM2
epsilon
Posted: 08:51pm 19 Feb 2021
Hi all,
My current project is getting large (or is it my head that's getting small?) and it's getting hard to keep track of where I put everything. Hence the following obvious little utility program:
Current Version: 0.1
Changelog
0.1: Initial Version
Description
xFind finds all occurrences of a given text string across files specified by a filespec or directory.
Usage
*xFind "text string" <filespec or dir>
Examples:
Search for text "SUB foo" in all .INC files in current directory:
*xFind "SUB foo" *.INC
Search for text "foo$()" in directory "bar" (and subdirectories):
*xFind "foo$()" bar
If no directory is specified, all files in the current directory (and subdirectories) are searched.
Search is case insensitive.
Required CMM2 firmware version
V5.06.00
To-Dos
Regular Expression matching
GitHub
https://github.com/epsilon537/xFind_cmm2
Cheers,
Ruben/Epsilon.
xFind.zip
Epsilon CMM2 projects
