Local Time 00:43 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : W10: No desktop icons and....
Posted: 11:07pm 15 Feb 2021
Hi all.
Another day, another W10 laptop.
This one boots fine, you can log-in fine, but there are no desktop icons, no taskbar, no "Start" button for the menu etc.  Mouse pointer moves around the blank screen fine.
CTRL+ALT+DEL works.
First thought that was they put it into tablet mode, but I cannot right-click anywhere on the blank screen, to bring up the menu to change that back to desktop mode.
Also, with no "Start" menu or taskbar, I am quite limited in what I can do.
Currently looking around on the net for things to try, but if anyone else has seen this and knows how to fix it, I would appreciate a post here.
Posted: 11:22pm 15 Feb 2021
Ran SFC /scannow, which found errors and fixed them, but still no icons.
None of the usual Windows shortcut keys work, such as WINDOWS+R for the run window, or WINDOWS+I for the settings - those key combinations do nothing at all.
Right-clicking anywhere on the blank background does NOT give me the right-click menu at any time or at any position.
Curious....
Perhaps use a W10 boot USB and select repair installation?
palcal
Posted: 11:38pm 15 Feb 2021
Would this help
Boot options
Posted: 12:15am 16 Feb 2021
Thanks - forgot about that path!
Used system restore to roll back to January automatic restore-point, but still have exactly the same problem.
That was surprising.
I expected to get the desktop back after doing a system restore to an earlier point....
hitsware2
Posted: 01:41am 16 Feb 2021
I ' ve gotten some good help here :
my site
Posted: 06:00am 16 Feb 2021
Thanks, I have signed up and posted a thread there also.
Paul_L
Posted: 07:38pm 16 Feb 2021
Hey Graeme, go to AskWoody.com, sign up, click on Forums, sign up, and post your problem.
Paul in NY
mclout999
Posted: 10:15pm 16 Feb 2021
  Quote  I expected to get the desktop back after doing a system restore to an earlier point...
If you have older restore points try them(sometimes listed in by hitting a highlighted text that says something like additional restore points).  I have had systems that did not resolve on the first restore point. On One particular system, the 4th one took and then I suspended updates of a month.  Worth a try.
