Forum Index : Microcontroller and PC projects : Sprite help!!!
| yock1960 Senior Member Joined: 18/08/2020 Location: United StatesPosts: 167 |
Okay, I've pulled out all of my hair and read and re-read the manual and forum to try and find an answer to this problem...not to say that I haven't missed something...but I just can't find a solution....short of placing 'on error skip' before all sprite commands. Likely that wouldn't work either. Attached is a WIP of my attempt to re-create a Qbert-ish clone. It will play (with Classic joystick) for a while, perhaps even to as far as I have levels setup, but invariably, the 'dreaded' 'sprite internal error' will strike. Since I don't know what triggers this, apart from repeated hiding/showing of sprites...I can't fix it. I don't think I'm doing anything 'illegal' since it works...but perhaps I'm just not doing things as it was imagined they would be done...I don't know. I did try a 'trick' of vegipete's that I saw last night, of not hiding, but moving sprites offscreen...but after changing all of the 'hides' to show sprite x,mm.hres-1,mm.vres-1...strange things happened...a do loop broke and then I kept getting a weird error about an illegal character (double quote) , where I'd never seen before and just didn't make any sense! The code is not well documented, not optimized, filled with extraneous code....and...has undergone a couple of re-thinks. On the fly re-defining of some sprites being the big one. I'd appreciate any thoughts on a solution! Steve qbert.zip |
Can't help about the rest, but "illegal character (double quote)" sometimes means that the non-ascii opening double-quote or closing double-quote has been copied from another source. You might try replacing that. Or sometimes it's an invisible character (e.g., em-space or en-space). PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
It is impossible to help with a program this big. There may be a firmware bug or you may be using the firmware in a way that wasn't anticipated and isn't being trapped. If you can create a simple program that demonstrates the issue I will of course look at it. Things to think about: Avoid ever using ON ERROR - your code should know its own state and not do things that need error trapping. If it was up to me I would remove ON ERROR completely. This one sounds suspicious. Are you using it on any "copied" sprites? That could be an issue that may not be being trapped |
The on error statements were a crutch certainly, originally for not hidden or not shown errors, I know how to fix this now. No, no copied sprites were involved in 'on the fly' re-definition. Based on your response, I went back to an earlier version, before on the fly definition and the sprite internal error problem goes away, so it seems as if re-defining...repeated read sprite statements, which is not forbidden...is problematic. I've even tried closing before 're reading', it doesn't help. The reason I do this, is because the orientation capability wasn't working for me....the sprite would be in the wrong place. If I could figure out how to make this work...it would potentially solve the issue. I guess I'll go back and look at this to see if I 'imagined it' or if I need to 'track' orientation to compensate when showing sprites or if there is another solution. I'll work on a test program, maybe it will shed some additional light on the problem, of itself. Steve |
