Local Time 01:42 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite F4: BLIT WRITE seem to interfere with string array
Posted: 07:15pm 08 Feb 2021
Using the bmp file in the attached zip, this code shows the problem I'm seeing:
Dim integer i,j,k,x=10,y=0,lblue=RGB(172,209,255)
box 0,0,320,240,,rgb(white),lblue
dim string labels(10)
for i=0 to 10: labels(i)="Label "+str$(i):next i
font 7: cls lblue
x=0:y=0:for i=0 to 10:
 text x,y,labels$(i),,7,,rgb(black),lblue:
 print str$(i)+": "+labels$(i): y=y+12:
next i
do while inkey$="": loop
geticons
cls lblue:x=0:y=00:for i=1 to 6:blit write i,x,y,50,50:x=x+52:next i
cls lblue
next i
x=100: y=0: for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: y=y+12: next i
blit write 1,80,180,50,50
x=200: y=0: for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: y=y+12: next i
end
sub geticons
'local integer i,j,k,x,y
Load image "icons.bmp"
for i=1 to 9: on error skip: blit close i: next i
k=1:x=0
for i=1 to 3
 y=0
 for j=1 to 3
   blit read k,x,y,50,50: y=y+50:k=k+1
 next j
 x=x+50: y=0
next i
end sub
First I PRINT and TEXT 11 string array elements to the LCD and await a keystroke; then I load the bmp file, extract 9 BLIT buffers and await a keystroke; then I BLIT WRITE 6 of the BLIT buffers and await a keystroke; then I again TEXT and PRINT the same 11 string array elements to the LCE and await a keystroke, but they are garbled.
Is there anything evident that I am doing wrong? ARMmite MMBasic Version 5.05.10.
icons.zip
Edited 2021-02-09 05:17 by lizby
Posted: 07:35pm 08 Feb 2021
Further info: after rebooting, the program works the first time, but not subsequently.
disco4now
Posted: 04:47am 09 Feb 2021
It looks like the line
causes a few problems. The next read of blit seems to overwrites the variables in the program.
See code below where I have put the closing of the BLIT buffers at the end of the main program and removed ON ERROR SKIP. Once the CPU is restarted runs OK from then on.
I think relying on ON ERROR SKIP to manage the opening/closing of the BLIT buffers
is probably not a good practise.
Gerry
font 7: cls lblue
next i
geticons
cls lblue
next i
' Close the buffers here
for i=1 to 9 : blit close i: next i
end
sub geticons
' Dont use on error to hide the errors
'for i=1 to 9: on error skip: blit close i: next i
k=1:x=0
for i=1 to 3
y=0
for j=1 to 3
next j
x=x+50: y=0
next i
F4 H7FotSF4xGT
Posted: 09:15am 09 Feb 2021
  Quote  It looks like the line
Perfect diagnosis which has allowed me to find the problem instantly. I'll post an ArmmiteF4 firmware update later today
Posted: 01:40pm 09 Feb 2021
Excellent. Thank you.
I put the BLIT CLOSE i at the beginning because if the program fails, and the BLIT buffers have not been closed, BLIT READ will fail at the next run of the program because unlike on the CMM2, the BLIT buffers appear to persist in some way between program runs.
(If that is fixed, it would be great--they'd never have to be closed in my usage thus far.)
Posted: 01:10pm 10 Feb 2021
With the new F4 MMBasic, I no longer need to do BLIT CLOSE for each BLIT buffer before a program is rerun. That's good.
But there's a new oddity: after running the program and quitting with Ctrl-C, I get  "Error : Not enough memory" when I run FILES. MEMORY reports "26K (24%) Free".
Dim integer lblue=RGB(172,209,255),grey=rgb(192,192,192),i,j,k,l,m,n
Dim integer EspFlag=0,iconFlag=1,txtFont=1
Dim integer ls%(2000),nNames=9,degrees, x_endpoint, y_endpoint
'Dim cx% = 225, cy% = 100, wid% = 50
Dim cx% = mm.hres*.75-20, cy% = (mm.vres-40)/2+20, wid% = mm.hres/6
Dim ang! = 0.087266463, rad90! = 1.570796327  '90 degrees in radians
Dim string a$,b$,c$,d$,item$,Values(10) length 20
Dim string names$(10) length 15
names(0)="description":names(1)="temp":names(2)="pressure":names(3)="humidity"
names(4)="speed":names(5)="deg":names(6)="gust":names(7)="country":names(8)="name"
Dim string labels$(10) length 25
labels$(0)="Sky": labels$(1)="Temperature": labels$(2)="Atmospheric Pressure"
labels$(3)="Humidity": labels$(4)="Wind Speed": labels$(5)="From the"
labels$(6)="Gusting to": labels$(7)="City": labels$(8)=","
Dim string points$(16) length 3  =("N","NNE","NE","ENE","E","ESE","SE","SSE","S","SSW","SW","WSW","W","WNW","NW","","")
points(15)="NNW": points(16)="N"
if iconFlag then: geticons: endif
box 0,0,mm.hres,40,,rgb(white),grey
box 0,40,mm.hres/2,mm.vres-40,2,rgb(white),lblue
box mm.hres/2+1,40,mm.hres/2,mm.vres-40,2,rgb(white),lblue
text mm.hres/2,5,"Weather: Milton, Nova Scotia",C,1,,rgb(white),grey
text mm.hres/2,20,date$+" "+time$,C,1,,rgb(white),grey
compass_rose cx%,cy%,wid%
if mm.hres=320 then: txtFont=7: endif
getWeather
x=10:y=45:
for i=0 to 6
 if i=2 then
   text x,y,labels$(i)+": ",,txtFont,,rgb(black),lblue:y=y+15:
   text x,y,"  "+Values$(i),,txtFont,,rgb(black),lblue:y=y+15:
 else
   text x,y,labels$(i)+": "+Values$(i),,txtFont,,rgb(black),lblue):y=y+15:
 endif
next i
circle cx%+15,cy%+15,wid%-6,,,lblue,lblue
circle cx%+15,cy%+15,wid%/8,,,rgb(red),rgb(red) ' center
n=(degrees+270) mod 360
for i=12 to 18 ' lines offset from center (cx%+15) to make arrow
 x_endpoint=(cx%+15)+(Cos(n*ang!)*(wid%-8))
 y_endpoint=(cy%+15)-(Sin(n*ang!)*(wid%-8))
 Line (cx%+i),(cy%+i),x_endpoint,y_endpoint,,RGB(RED)
'  Line (cx%+i),(cy%+i),(cx%+15)+(Cos(n*ang!)*(wid%-8)),(cy%+15)-(Sin(n*ang!)*(wid%-8)),,RGB(RED)
next i
text x,200,"Condition:",,txtFont,,rgb(black),lblue
if iconFlag then
 blit write 2,mm.hres/4,180,50,50
else
 text x+10,212,Values$(0),,txtFont,,rgb(black),lblue
endif
do:loop
sub compass_rose cx%,cy%,wid%
Local a%
Text cx%+9,cy%+15-(wid%+17),"N",L,1,,RGB(1,1,1),lblue
Text cx%+9,cy%+15+(wid%+5),"S",L,1,,RGB(1,1,1),lblue
Text cx%+wid%+20,cy%+4,"E",L,1,,RGB(1,1,1),lblue
Text cx%-(wid%)+5,cy%+4,"W",L,1,,RGB(1,1,1),lblue
if a%<>a% then
Text 10,10,"NE",L,7,,RGB(1,1,1),RGB(134,174,230)
Image rotate 6,4,30,30,cx%+(wid%-16)*Cos(.785),cy%-(wid%-16)*Cos(.785),45,1
Text 10,10,"SE",L,7,,RGB(1,1,1),RGB(134,174,230)
Image rotate 6,4,30,30,cx%+(wid%-16)*Cos(.785),cy%+(wid%-16)*Cos(.785),135,1
Text 10,10,"SW",L,7,,RGB(1,1,1),RGB(134,174,230)
Image rotate 6,4,30,30,cx%-(wid%-16)*Cos(.785),cy%+(wid%-16)*Cos(.785),225,1
Text 10,10,"NW",L,7,,RGB(1,1,1),RGB(134,174,230)
Image rotate 6,4,29,29,cx%-(wid%-16)*Cos(.785),cy%-(wid%-16)*Cos(.785),315,1
Text 10,10,"  ",L,7,,RGB(134,174,230),RGB(134,174,230) ' clear text
' tick marks, every 5 degrees (360/5 = 72)
endif
For a% = 0 To 71 ' note: for angles, East is zero
 Line (cx%+15)+(Cos(a%*ang!)*(wid%-4)),(cy%+15)-(Sin(a%*ang!)*(wid%-4)),(cx%+15)+(Cos(a%*ang!)*(wid%+1)),(cy%+15)-(Sin(a%*ang!)*(wid%+1)),,RGB(WHITE)
Next
' COMPASS perimiter
Circle cx%+15,cy%+15,wid%
Circle cx%+15,cy%+15,wid%-4
Sub getWeather
if EspFlag then:
else
Open "livr.jsn" For input As #1
Do While Not Eof(1)
 Line Input #1, a$: ' Print a$
 LongString append ls%(),a$
Close #1
' LongString print ls%(): Print
For n=0 To nNames-1
 item$=names$(n)
 Values$(n)=pseudo_json$(ls%(),item$)
'  Print item$,Values$(n)
 If item$="temp" Then: Values$(n)=Str$(Val(Values$(n))-273.15)+"C": EndIf
 If item$="deg" Then
   degrees=Val(Values$(n))
   i=(degrees+11.25)/22.5
   Values$(n)=points$(i)
'    print item$,degrees,i,Values$(n)
 If item$="humidity" Then: Values$(n)=Values$(n)+"%": EndIf
 If item$="speed" Then: Values$(n)=Values$(n)+"kph": EndIf
 If item$="pressure" Then: Values$(n)=Values$(n)+" millibars": EndIf
 If item$="gust" Then: Values$(n)=Values$(n)+"kph": EndIf
Next n
endif
Function pseudo_json$(ls%(),key$)
 local integer i,j,k,l,m
 local string a,b
 m=1
 pseudo_json$=""
   i=LInStr(ls%(),key$,m)
'    Print key$,i
   If i Then
     a=LGetStr$(ls%(),i-1,1)
     b=LGetStr$(ls%(),i+Len(key$),1)
'      Print "|";a;"|","|";b;"|";
     If a=Chr$(34) And b=Chr$(34) Then ' found the key
       j=LInStr(ls%(),",",i+Len(key$)+2)
       If j>0 Then
         k=i+Len(key$)+2
         a=LGetStr$(ls%(),k,j-k)
'          Print a
         If Mid$(a,1,1)=Chr$(34) Then ' remove "s
           a=Mid$(a,2,Len(a)-2)
         If Instr(a,"}") Then: a=Mid$(a,1,Len(a)-1): EndIf
         pseudo_json$=a
         Exit Do
     m=i+Len(key$)
   Else
     Exit Do ' key not found
End Function
sub geticons
k=1:x=0
for i=1 to 3
 y=0
 for j=1 to 3
 next j
 x=x+50: y=0
next i
end sub
This uses the same "icons.bmp" as before.
> run
> files
> memory
Flash:
  5K ( 3%) Program (157 lines)
139K (97%) Free
RAM:
 20K (17%) 32 Variables
 68K (59%) General
 26K (24%) Free
Posted: 01:13pm 10 Feb 2021
The BLIT buffers are left in place after Ctrl-C and they use memory so you need to close them before using FILES - this uses memory to sort the filenames
