Local Time 01:42 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Mode 8,12 and Right Edge
vegipete
Posted: 11:27pm 07 Feb 2021
MMBasic Version 5.07.00b2
With the above firmware, I notice a problem trying to draw on the very right edge of the screen in mode 8,12
mode 8,12
cls
box 0,0,320,200
do:loop
The right side of the box doesn't appear. Works fine in mode 3,8
Likewise, nothing appears with "line 319,0,319,199".
And no, it is not the monitor.
(I'm not sure where to report bugs right now...)
Posted: 03:57am 08 Feb 2021
I assume you mean MODE 3,12 not 8,12
I agree that the right hand column appears to be missing in mode 3,12 but visible in mode 3,8 and 3,16
mode 3,12
cls
line 318,0,318,199,1,rgb(green)
line 319,0,319,199,1,rgb(red)
'box 0,0,319,199
do:loop
vegipete
Posted: 05:28am 08 Feb 2021
Whoops, yes, mode 3,12.
Posted: 08:55am 08 Feb 2021
Thanks for the report - will have a look
UPDATE
Fixed in b12
Edited 2021-02-09 02:19 by matherp
Pilot352
Posted: 06:18pm 08 Feb 2021
If the right side is drawn, wouldn't that mean the width of the screen is 201 pixels? You are starting at 0. Range should be 0-199 not 0-200. Or am I wrong?
Posted: 06:21pm 08 Feb 2021
  Quote  Or am I wrong?
Yes
BOX x,y,w,h
LINE x1,y1,x2,y2
