Local Time 04:37 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit Lost Find/Replace
Chopperp
Posted: 11:31pm 25 Jan 2021
For TassyJim
I removed one of the monitors from an older PC with MMEdit on it & now have lost the Find/Replace box. I'm assuming that the PC/MMEdit thinks it is on the monitor that is not there. It comes up in the Task Bar OK.
Is there a simple way of getting it back onto the single monitor with the main program apart from reconnecting the other one & moving it across?
Brian
ChopperP
Posted: 12:17am 26 Jan 2021
Assuming MMEdit V4
In the data folder there is a file "mmedit4.inf"
data folder location can be found from Help/About
If you delete that file (with MMEdit shutdown), it will get recreated with the default settings.
If you don't want to loose all of your settings,
With MMEdit shut down, open the mmedit4.inf file with any text editor and find the section on locations
[Locations]
mainWinLoc                       = 1242 952 584 120 80
configWinLoc                     = 479 411 114 44
chatWinLoc                       = 812 783 1012 163 1 0
fileWinLoc                       = 763 652 601 90
HintWinLoc                       = 688 300 602 160
ReportWinLoc                     = 785 599 1003 185
FindWinLoc                       = 248 186 947 130 0 0
Delete the line "FindWinLoc"
restart MMEdit
Chopperp
Posted: 12:32am 26 Jan 2021
  TassyJim said  Assuming MMEdit V4
Oops, Old PC, not used much. Will update to V4
Thanks Jim
EDIT
Updated OK
Edited 2021-01-26 10:42 by Chopperp
ChopperP
