Local Time 04:36 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Basic - passing by reference help
Nimue
Posted: 01:29pm 22 Jan 2021
I have written code to check for palindromic hex and binary numbers.  Except it doesnt work -- due to passing by reference and I can't find a way out of it:
Function reverse(in_string$) As string
   For i = Len(in_string$) To 1 Step -1
       b$=Mid$(in_string$,i,1)
       r$=r$+b$
   Next i
   reverse$=r$
End Function
For i = 1 To 100
   If Bin$(i) = reverse(Bin$(i)) Then
       If Hex$(i) = reverse(Hex$(i)) Then
           Print i,Bin$(i), Hex$(i)
Next i
The function works fine (outside of the for loop)  as does the hex / bin conversions.  The link between the loop and the function breaks and this leads me to think is a passing issue (by reference?)
Any minds greater than mind have a look at this for me please?
Nim
Edited 2021-01-22 23:30 by Nimue
Posted: 01:36pm 22 Jan 2021
Hi Nimue,
Unfortunately I'm not near my CMM2 so can't run it for myself.
I can't see an obvious pass-by-reference issue; reverse() doesn't do any "write operations" to in_string$.
I'm a little suspicious about the reverse$=r$ line when the Function is called reverse not reverse$, but that might be harmless. I generally don't mix the !%$ suffixes with the AS form.
How does it not work? Can we have some sample output.
Nimue
Posted: 01:52pm 22 Jan 2021
  thwill said  Hi Nimue,
What I get is "String too long".
If I add an extra print in the For Loop:
For i = 1 To 100
   Print i  ' Debug
   If Bin$(i) = reverse(Bin$(x)) Then
Next i
I get:
1
1
1
1
1
1
1
etc
etc with the loop not incrementing until the string error.
Exactly the same happened before on a project where passing was the issue IIRC.
The reverse function works well on its own:
print reverse("Nimue") produces the desired output of a reversed string.
N
Posted: 01:56pm 22 Jan 2021
The first obvious bug is that i and r$ are global variables and are never re-initialised after the first time it is used. i in particular is buggered by the subroutine
USE OPTION EXPLICIT!!!!!!!!!
Posted: 01:58pm 22 Jan 2021
  matherp said  The first obvious bug is that i and r$ are global variables and are never re-initialised after the first time it is used. i in particular is buggered by the subroutine
That will be it ;-) That will teach me to ignore the obvious.
Edit: Languages with implicit declaration are a 'mare ... and personally I don't have anything good to say about languages with implicit typing.
Edited 2021-01-23 00:02 by thwill
jirsoft
Posted: 02:00pm 22 Jan 2021
I'm missing the bold part.
  r$ = ""
      r$=r$+b$
  Next i
  reverse$=r$
End Function
For i = 1 To 100
Next i
Or simpler:
  reverse = ""
      CAT reverse, Mid$(in_string$,i,1)
  Next i
End Function
Jiri
Posted: 02:05pm 22 Jan 2021
  jirsoft said  Or simpler:
  reverse = ""
  Next i
End Function
Simpler, but wrong
- 'reverse' doesn't need setting to "", that is the default on entry.
- 'i' is an undeclared global as Peter said.
  local r$
  local i
      r$=r$+b$
  Next i
  reverse=r$
End Function
For i = 1 To 100
Next i
Nimue
Posted: 02:34pm 22 Jan 2021
DOH!!!!
Nimue
Posted: 02:35pm 22 Jan 2021
  local r$
  local i
      r$=r$+b$
  Next i
  reverse=r$
End Function
For i = 1 To 100
Next i
Thank you all for the comments and tweaks -- my own sloppy habits from Python krept in!!.
Nim
Nimue
Posted: 12:24pm 23 Jan 2021
Thank you for your help on this the other day.
I use my CMM2 to indulge my hobby of working on number sequences:  https://oeis.org/A340559 << where you will see that I have added MM Basic solution to this sequence.
Nim
