Local Time 05:39 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 3D Effects with Radial Gradients = Cheap low resorce sudo 3D
mclout999
Posted: 04:52pm 17 Jan 2021
I have been thinking about this for a while and I may be off base but would it be possible and beneficial to add Radial gradients in the graphic primitives or as a flood fill that are keyed to the light source of the 3D engine.  It is an old trick to efficiently archive Sudo 3d effects with rater low resource demands. There are a lot of articles on the technique like https://www.ellenfinkelstein.com/pptblog/3d-effects-with-radial-gradients/ and https://helpx.adobe.com/photoshop/using/gradients.html
Drop shadows may also be cheap to implement.
I am not sure if this is a good idea but I thought I would propose it as an option to augment the 3D side of things. Feel free to disregard if this is either too difficult or not beneficial enough to bother.   thanks.
